Question about Honeywell Programmable Thermostat Heater
Replacing Honeywell heating progrmmer
Hi I have a Honeywell ST699 programmer and would like to upgarde to an ST6400c. How difficult will this be, is the wiring common?
  • AllanJ Jan 12, 2009
    I've got a problem too with the ST699. However I can't see how to either get it off the wall or unscrew the front. Any ideas please?
    Problem Solver:
  • 17 Answers
Yep the wires will hook up to the same designations, just write down what color was connected where. You will need to set the thermostat up for your particular situation...gas, electric, heat pump, ect. The installation maunel is very clear on this aspect so you should not have a problem.
Posted on Nov 14, 2008
For AlanJ the Honeywell ST699 front plate pulls out of the rear mounting box - you can help it (having isolated power obviously) and sliding a blunt knife or similarly thin tool into the rear box along the top surface. There are 3 tabs that hold the two plastic halves together, two on the top surface and one on the bottom left. The blade helps the tabs disengage. Rgds Nick
Posted on Oct 07, 2009
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
Our heating and hot water keeps turning off
Sounds like a glitche in the thermostat. First, override the program & see if it does the same thing over the next few days.
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Hi I have a Honeywell st699 programmer for central heating and hot water. The only problem that we have is that we can not change the time on the clock. This means that we cannot set any programmes. Is it...
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 17, 2010 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Sep 17, 2009 | Honeywell Electronic Programmable...
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
May 08, 2009 | Honeywell Programmable Thermostat Heater
No hot water honeywell st6400c
HW valve was stuck in the open posiion and the micro-switch was not working so thats why boiler and pump were not starting. Bled system to below the level of the valve to be changed, and replaced valve with a drayton ( easy quick change of valve head if needed no screws )
Sep 07, 2008 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
914 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
