Cars & Trucks Logo
Matthew Beasley Posted on Mar 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What alternators interchange with a 94 lebaron?
Mike
Level 3:
  • Chrysler Master 4,383 Answers
  • Posted on Mar 02, 2012
Mike
Chrysler Master
Level 3:
Answers
4383
Questions
Helped
1261537
Points
17064
Ask the guys at your local wrecking yard, they know interchangeability, the rest of us either rebuild our unit, or replace with a rebuilt unit of the correct specs.
2 Related Answers
Anonymous
  • 582 Answers
  • Posted on Aug 11, 2009
SOURCE: i have a 1993 s10 and i have an alternator for a
LOOK AT THE UNITS CLOSLEY DO THEY BOLT UP THE SAME IF SO, CHECK THE ALTERNATOR FOR NUMBERS AMP OUTPUT SHOULD BE ON BOTH UNITS NEVER REPLACE A UNIT WITH LESS AMP OUTPUT, MORE NEVER HURTS LESS CAN CAUSE PROBLEMS
Patrick Rayome
  • 1757 Answers
  • Posted on Apr 06, 2010
SOURCE: diagram for timing marks 94 lebaron 3.0litre
Click on the following free, direct Link. It has all the Timing Belt Diagrams with Marks you will need for your 1994 Chrysler LeBaron 3.0L.
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1994/make/chrysler/model/lebaron/1994_chrysler_lebaron_timing_belt_diagram_marks.htm
1994 Chrysler LeBaron 3.0 V6. I need to find a vacuum pump for a 94 lebaron please.
Question edited for clarity, add maker, fix spelling.
Question moved to correct category.
Strangely, Google doesn't find your 'vacuum pump', so the wording must be incorrect. Brake Booster?
https://www.google.com/search?q=1994+Chrysler+LeBaron+3.0%2C+vacuum+pump
Will Altenator interchange between 94 Toyota and 02had Toyota Tacoma
No idea ,so long as the brackets fit then alternator will fit even if you have to swop the puleys over abd make the wiring connections to fit ,ok if one alternator is say 70 amp and the other 90 amp it will still work good enough for what you want
6helpful
Diagram for timing marks 94 lebaron 3.0litre
I need to determine if a gas tank off of a Spirit will interchange with the tank from a 1990 Chrysler Lebarron convertible
The Lebaron, depending on which model has either a 14 or 16 gallon tank. A 1990 Spirit gas tank has only a 16 gallon tank. If your Lebaron has a 16 gallon tank it is exactly the same part.
1helpful
2answers
Do you have a diagram on how to install a serpentine belt on a 1994 Chrysler LeBaron?
1994 CHRYSLER LEBARON - V6 3.0L 2972cc 181ci GAS FI N 3
Open the hood, the diagram for the serpentine belt is on the cowling.
From DAYCO Catalog
Belt Routing Diagram (Alt., P.S., Idler & Tens.)
From comments to other users and Lebaron Owners; for remove, starting at the alternator pulley and going clockwise around the pathof the belt, the belt drops down and forward and goes under the idlerpulley, continues forward and less steeply downward and goes around thecrankshaft pulley clockwise, rises rearward going over the top or thetensioner pulley counterclockwise, then drops down and around the powersteering pump clockwise and rises to go around the alternator pulleyclockise (which is where I started the description). To loosen thetension to remove the belt, or to give you slack to install the beltwithout having to force it over a pulley while under tension you rotatethe tensioner pulley arm around its pivot clockwise according to the'94 shop manual. It doesn't show by what means to effect this rotation,but in the earlier manual I have ('89) it shows there to be a 1/2"square hole in the tensioner arm into which you insert a breaker barwith a 1/2" square drive which gives you the temporary lever to rotatethe tensioner against its spring action. I assume there is a similar1/2" square hole on the '94 you are working with. Interestingly,between '89 and '94 the idler pulley was added, and the requiredrotation of the tension arm changed from counterclockwise to clockwiseto relieve the tension."
I think this will help you get the belt on. Good luck.
1helpful
2answers
Where can i find a diagram to install serpentine
Most parts stores can print this out for you for free.
2answers
1994 J30 Alternator
Should not be a problem. Your engine is the VG30DE, which is the same engine in the 90-96 non-turbo 300ZX. On those cars, the alternators were all interchangeable, so I see no problem with using an alternator from a different model year than your car.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
