Question about Pasquini Moka Coffee Grinder
I'm having problems with the unit, unable to program it and on the program button the light is blinking 10 times in a roll also it has started running by itself every few seconds this all started after a circuit in the breaker box blew and had to be reset.
The light in my Homelink system does not come on. Therefore it cannot be programmed.
The following are steps to programming a rolling code door opener to the Homelink transmitter in the Touareg.
The instructions in the owner's manual are correct, but after following them, my garage door installer and I discovered a few quirks and fixes for them.
It is important to park the Touareg in front of the garage door. Be careful not to park underneath it. rolleyes.gif
If your remote garage door transmitters are already programmed to your door opener, you need to do the following steps:
1. On the garage door opener itself, there is a learn button. Press and hold down the learn button until the learn indicator light goes out (approx. 6 seconds). (The learn button is near the antenna on your door opener.) By doing this, you have just reset the codes. At this point your remote door transmitters will most likely not work. This is o.k.
2. In the Touareg, press and hold whichever homelink button you want to program until the light above the homelink buttons slowly blinks. Continue to hold the button in and at the same time, hold your remote transmitter underneath the map lights and press the button. Continue to press both buttons until the homelink light rapidly flashes. Let go of both buttons.
3. You now have 30 seconds to press the learn button on your garage door opener. Press it once. The light will start to blink.
4. Go back to the Touareg, press and hold the homelink button you just programmed for 3 seconds until you get a blinking light. Repeat again. This time, it should open or close the door. The homelink button is now programmed.
5. Now that the homelink button is programmed, you now have to re-program your remote transmitters. Take the transmitters with you.
6. On the garage door opener, press the learn button, the light will blink. Now press the button on the remote transmitter. The light should stop blinking. Repeat the step if you have more than one transmitter. You should be all set. The homelink button should work in the Touareg and your remote transmitter(s) should also work.
In summary, the rolling codes in the door opener receiver have to be reset. For some reason, the Touareg has to be programmed FIRST. Then the remote transmitter units. If the remote transmitter units are already programmed, you will most likely not be able to program the homelink in the Touareg for a rolling code door opener.
Original Launch X-431 DIAGUN III
Mar 14, 2013 | Cars & Trucks
Turn on unit and red and green lights blink together
Drum roll............................and the unit is?
Need laptop manufacturer and model number. Model number can be found on the bottom of the laptop.
In the meantime; with the laptop off remove the AC adapter (Charger), and Battery.
Press the Power On Button in, and hold for a count of 10 seconds.
(And I mean 10)
Let go of the Power On Button. Do this procedure two more times.
Now reinstall the Battery, plug the AC adapter back into laptop;
THEN into power.
WAIT 1 minute, turn the laptop on.
Post back in a Comment.
Regards,
joecoolvette
Dec 21, 2012 | Computers & Internet
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Green and red light on doesn't print
Maintenance request error is not cleared until the waste ink pad is replaced with a new one, and the waste ink counter in EEPROM is reset by the service operation.
"try in this procedure
1. hold and press ink and roll button then press power on.
2. Red Led 10 times blinking
3. release roll button.
4. press ink button until all light blink at a time
Dec 31, 2009 | Epson Stylus Photo 1290 InkJet Printer
I have lost manufacturers manual on my BMW 325ci 2001 model. i only require pages relating to the programing of automatic garage door thank you
NOTE: Some vehicles may require the ignition to be turned on or to the second (or"accessory") position for programming and/or operation of HomeLink. It is also recommended that a new battery be replaced in the hand held transmitter of the device being programmed to HomeLink for quicker training and accurate transmission of the radio frequency. Please use a ladder and do not stand on your vehicle during the programming steps for a rolling code opener.
Rolling Code Programming:
1. Press and hold the two outer HomeLink buttons until the indicator light begins to flash (after 20 seconds). Do not hold for longer than 30 seconds. Do not repeat this step to program additional HomeLink buttons.
2. Place the hand-held remote 1-3 inches from the HomeLink button you want to program.
3. Simultaneously, press and hold both the HomeLink and hand-held remote buttons. Do not release either button until step 4 has been completed. (If you reside in Canada, refer to the "NOTE" below.)
4. When the indicator light changes from a slow blink to a rapid flash, release both buttons.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the"learn" or "smart" button (usually near where the hanging antenna wire is attached).
6. Press and release this "learn" or "smart" button. (The name of these buttons vary by manufacturer.) There are 30 seconds in which to initiate step 7.
7. Firmly press, hold for two seconds, and release the programmed HomeLink button. Do this procedure again and, depending on the make of your garage door opener, do this procedure a third time to complete the procedure.
The garage should now activate when the programmed HomeLink button is firmly pressed and released. If not, give us a call or refer to the "Troubleshooting Tips" noted below. NOTE: If you reside in Canada, replace step three with the following: Press and hold the desired HomeLink button and "cycle" the hand-held remote. To cycle: Press and release the hand-held remote button every two seconds until the indicator light changes from a slow blink to a rapid flash(step four).
Troubleshooting Tips:
** Check the frequency of the garage door opener's hand-held remote (usually found on the back). HomeLink is compatible with radio-frequency devices operating between 288-399 Mhz.
** Put a brand new, store bought battery in the hand held remote. During the programming process (step three above) the battery's energy tends to drain (more so with an older battery). A new battery will increase the speed and accuracy in which the hand-held remote sends its signal to HomeLink.
** Retrain HomeLink holding the hand-held remote at different lengths and angles from the HomeLink button you are trying to program (during programming step three). Try 4-6 inches away at a different angle.
** Confirm that the HomeLink button you are trying to program is in the "programming mode". Press and hold the desired button. The indicator light will be a slow blink when HomeLink is in the "programming" mode and can be programmed at any time.
Verifying HomeLink has picked up a rolling code signal:
** Press and hold the programmed HomeLink button. If the indicator light blinks rapidly for two seconds and turns solid, HomeLink has successfully picked up the rolling code signal. If necessary, proceed with steps 5-7 noted above to complete the rolling code programming.
Sep 09, 2009 | 2001 BMW 325
Remoteless
the light that blinks really would be the lightbulbs on the machine ,to programm the remote you must first press the smart button on the machine and then press the button that you would like to program on the remote , now you watch for the lightbulbs to click off and then on again , this is the machines way of saying i accepted the code , check your manual for the location of the smart button ,some machines have them on the left for two light units that are side mount or some of the units also have them on the rear of the machine ,theese are usually brightly colored square plastic buttons , it will also have a small led light beside it that blinks from time to time , this would be the rolling code technoledgy of todays more modern openers , You can also remove the plastic light covers to see this button ,remember wherever the bell wires and infrared wires from the senser go ,That will be the location of the smart button ,because that would be the mother board where all the functions are performed , Hopefully i was able to help you and i Thank you for the question ,now get crackin and program that remote Sincerly Glenn Mayer
Sep 30, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Coffee Makers & Espresso Machines Logo
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
