Question about Reddy Heating & Cooling
Transformer for a 70k kerosene heater
Reddy heater 70k kerosene heater need transformer for model 388643 and I bet you can't help
    New Friend:
Often times it is the coil as I have just found out. I needed a coil with a long wire with more power since I have a large fan. A smaller fan with less air traveling needs less power ! This is a common cause for the heater not to run with the lid on. So you are in effect blowing the spark out. I got a transformer and it was from here. http://www.torpedoheat.com/
Worked like a charm.
Posted on Jan 21, 2016
  • 232 Answers
When I turn on the igniter comes but won't do the burner flame
The heater will not ignite, but this problem could have several causes! Do you mean that the motor is running, fuel at the nozzle but although there is a spark, the fuel does not ignite? This could be caused by low pump pressure, loss of spark could be the HT cables, or the ignition transformer. Is the electrode in good order?? An intermittent spark could be faulty electrodes or ignition transformer. Is the fuel clean and the correct type?? Is the fuel contaminated with water, is the fuel filter clean?? Dirty fuel could cause this problem.
Jun 25, 2014 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater pro 110
check that power is getting to the transformer, if so test the transformer for continuity. if it is good look for a short in the high voltage(spark plug) wire, and that one side of the secondary is connected firmly to the chassis of the heater. if no power to the transformer then trace the wiring to find the defect.
Mar 23, 2014 | Heating & Cooling
Need to know correct nozzle for heater. do not have a manual
Depends on the model of your heater. Which 70k heater do you have?
The nozzle might be PP208 or it could be 100735-18.
look at the chart
Mar 06, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
My heater runs great for about 15-20 minutes and then raw diesel comes out and it shuts down. I thought maybe the tank vent might not be working right so I tried running it with the tank cap off and it...
The transformer gets hot and stops making spark... then fire goes out....transformer cools down and it works till transformer gets hot...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 02, 2011 | Reddy R155D Utility Heater
Vogelzang kerosene heater will not ignite (no spark)
There is an igniter module and then the igniter electrodes (check the air gap) that produces the spark to start the fuel burning, both could be defective.
May 18, 2017 | Reddy Heater-30-55,000 BTU Variable
Heter trys to ignite,replaced igniter,cleaned fuel filter
1. Check the ignition transformer. It may be grounded,
or it could be defective, and need to be replaced.
2. You have already replace the igniter and the
photoeye.
3. Once the ignition transformer works, everything will
be alright.
May this tip help you.
Jan 04, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Kerosene Reddy Heater, fan comes on, but it won't ignite, it just blows kerosene out the front. There is no electricity getting to the plug. Please reply soon, I need it tomorrow!! Thanks
Your description does not leave much to go on, because you don’t state the model heater that you have. You see, there are 2 different technologies that come into play on portable kerosene heaters. First there is the older version spark plug type heater, and, second there is the newer computerized type with Hot Surface Ignitor (HSI) technology.
Since you state "There is no electricity getting to the plug", the KEYWORD here is PLUG. I am going to assume that you have a spark plug type heater. NOTICE: if your heater has HSI technology- disregard this post because it will not apply.
Causes for "no electricity to the plug":
  1. no electricity to the unit
  2. a defective Safety Control (reset)
  3. a defective photocell
  4. a defective Ignition Control (transformer)
  5. loss of ground to the Ignition Control
I am including a link to some troubleshooting tips for spark plug type heaters. These heaters are relatively simple, but, be careful. Stay away from the fan and take precautions from the obvious shock hazards. Troubleshoot each of the above until you find the problem.
Dec 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater works halfway
You did right by re-attaching the transformer to the heater. This re-established the necessary ground. And you are right, you messed up by turning the pump pressure adjustment screw. No big deal, though. Here's how to get back on track http://reddyparts.com/pressure.htm. .
Nov 16, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
174 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
