Model olympus T-110
Click start click to open on my computer you should see your camera card E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your camera card (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
SOURCE: Olympus c350, Memory card
Hi!
According to the user manual - the maximum size of memory card it can support is up to 256MB only. However, many users claim that it can support up to 512MB.
Have a nice day!
SOURCE: Olympus SP550UZ photos saved on camera memory not card
In the Menu if you go to the option that says Setup and press ok there should be an option that says Backup. This should allow you to copy the images from the internal memory to your xD card.
SOURCE: olympus xd memory card comupter says format
when I put the xd card in the camera ask to format click on yes reads "card error"
I only have xp home computer so can you come back with your proposed fix i did try but I think the problem is hardware as it is reading all cards as if they are write protected thanks for trying
for XP
Right click the icon of your usb drive (It should be E:/ or something)
Click permissions
you will need to have your camera connected to the computer
You can remove write protection from your usb flash drive which in your case will be your camera using the below method:
1. Open start menu, in the search bar type regedit and press enter. This wil open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key StorageDevicePolicies does not exist, you will need to create it manually.
3. Double click the key WriteProtect in the right window and set the value to 0 in the Value
Data Box and press OK button
4. Restart your computer and try copying files into your USB drives.
Registry Disclaimer:
Sometimes this problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted registry entries.
However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
For more information about how to back up and restore the registry, follow the steps as in the KB Article:
http://support.microsoft.com/kb/322756/
