Question about Fisher and Paykel GWL11 Top Load Washer
Won't spin or drain
bought 2 new bath towels and 2 hand towels yesterday and threw them in to wash. The machine will wash but won't drain.It gets to the drain cycle and starts beeping, I tried resetting it and that didn't work. I blew thru the drain hose and air is coming into the washer. There is tons of lint in the water so I have bailed out all the water and now what? I'm a bit confused as to how to check the pump. Someone please help before I register for the looney bin!
Thanks,
Terri
    Genius:
  • 1,028 Answers
Remove as much water as possible lean washer back against wall pump is on front of tub bottom pump twist locks into bottom of tub ..no tools needed pull release tab back and turn pump out and clean
Posted on Oct 31, 2008
We have Samsung WF448AAW steam, silver care washer. This problem only occurs on towel cycle. When we wash colored cotton terry bath towels and wash cloths there area areas about the size of your hand or...
Hi
This type of issues usually occur when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the bleach marks should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Whirlpool lsr8233eqo machine won't agaite or spin will drain
check belt,it mite of came off when unbalance.
or if it is a 2009 model,unplug wait 30sec. plug back in. hope this helps.
Oct 04, 2009 | Whirlpool Washing Machines
Very noisy on spin cycle, not out of balance
Hi, check leveling of machine, machine should be proper leveled on all side, use spirit level to adjust legs, there should be no rocking motion, in any direction after leveling, put hands on top of machine and try to rock it sids to side, there should be no movements, also check for overloading, be careful when washing things like bath towels, etc, they absorb lots of water, eg. one regular bath towel are equivalent, to six pants, six tops. or possible springs or bushings broken, you need open machine and check.
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
New HE washer not draining on spin and drain
Load was too light, needed to add a towel in order to wash nylons. I will be hand washing from now on. Washing machine doesn't do delicates to my satisfaction.
May 18, 2009 | Maytag Washing Machines
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
Washer not fully draining, even with extra drain/spin cycle...
Hi easterbunch;
Im sorry to have to tell you but that is one of the inherant faults of the duet line of machines. It is a safety guard that the machine sences as a unevenly distributed load, and prevents the unit from spinning up to full rpm's The next time you need to do a small load throw a bath towel or two in with it and you wonrt have any problems with it spinning up to full speed.
Hope this helps :-)
Feb 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Dec 18, 2007 | Frigidaire GLTR1670A Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
142 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
