Question about Dometic Rooftop RV Air Conditioner
Dometic Duo Therm
We are in australia and having trouble sourcing parts for our air cond. Can someone tell me the name of a reputable dealer who can advise me on spare parts. Ours is a B3253 or 3254. We cannot access parts for it in Australia. It is also a 13500BTU unit. The part we need has the following numbers on it. 3107541-009 serial no US154869.
Have you called dometic for the parts, what parts are they.
Posted on Nov 25, 2008
Where can I find a shroud for my 2003 model 59516.331 duo-therm high efficiency Dometic roof mounted dometic RV air conditioner?
Try googeling Camping world ,Adventurerv ,or best rv and truck supplies ,these are all in the USA who deliver to Australia.I usually find that it is much cheaper to buy parts like this from the US even with the delivery charge.
Good Luck John
Oct 11, 2012 | Dometic Rooftop RV Air Conditioner
I have a Duo-Therm air-cond/heat pump. When I have it in the air-cond. mode it cycles about every 5 minutes between air-cond. and heat pump. We are traveling & I called a repairman & he said he...
They should at least supply you with a dealer/technician in the area where you currently are to assist you. If that's all you need, I can do that from their site. With that said, yes, it sounds like an unusual problem. Can I ask if this just happened suddenly, was anything changed such as thermostat for example? Was it working ok, prior to this happening? Any other symptoms or changes that you can think of?
Oct 30, 2011 | Dometic Rooftop RV Air Conditioner
It is getting cold can you tell me how do i work the furnace part of my duo therm dometic air system
I hope this doesn,t sound patronising but i have seen people turn the themostat down to make the furnace come on obviously the thermostat has to be turned up to set for a higher tempreture , after a small time delay, should then light up.
Oct 20, 2011 | Dometic Rooftop RV Air Conditioner
I have a Dometic P/N Duo-Therm Model #59516-531 that started running more and more to cool my RV 5th wheel. I checked filter, drain, and noticed the unit was icing up. I turned off AC and let fan run to...
It is probably low on refrigerant. You can only check this if you have a set of gauges. Otherwise, take it to an air cond company and they will check it for you.
Jul 21, 2011 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Dometic duo therm a/c for rv
generally most R/v dealers should have those replacement parts they will have detailed diagrams that you can tell them exactly what you need
Aug 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
502 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
