Question about Frigidaire FTF530FS Front Load Washer
Self seal gasket for plastic drum
I have Kenmores version of this and first of all cannot believe the problems with these front load washers. I have had a drip from two of the lower bolts that hold the two piece plastic drum (that houses the s/s drum), apparantly there is a self seal gasket. This washer apparantly has always dripped, I tightened down the two bolts, was ok for a while and now again it drips water. I tried to get an esimate to replace this gasket (part#131275900). Sears wants $65 to have a man come to the house, look up the part and the repair exercise on this computer and give you a price, when they could just as easily give that info via e-mail or phone so one can determine if it makes sense to repair! Any one have an idea what the cost might be?
  • David Doran Oct 31, 2008
    Thanks, that just what I expected, a very high price to correct a bad design. I thought maybe a water proof adhesive spread along the area might help. I have placed a stove liner in the bottom and placed a sponge so that it will hold any water and at least keep the floor from getting wet and the floor of the washer from rusting any more than it is. Other than this issue the washer runs great and am holding my fingers crossed that the aluminum spider bracket (great you tube vido by a gentlemen who exposed that issue) does not fail me. Would like to get a couple more years out of this washer. Not sure these front loaders even though they save water and may get clothes alittle cleaner (not sure I can prove that poiint) are truly worth all the money and headaches. Sad, good idea, poor qualilty and design flaws put many, many consumers into a shock mode when problems arise.
    Thanks for you help.
    President:
  • Frigidaire Master
  • 2,651 Answers
Thats the main tub seal, youll need to remove the tub completly from the machine, split it and then reassemble after installing the new gasket and hope you didnt damage anything in theprocees. big bucks for the repair i bet, iim in NYC and id bet problalby 325-425, alott of labor involved!
Posted on Oct 31, 2008
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
How to clean the inside seal of a frididaire front load washer
Good Afternoon Friend,
I understand you want to know how to clean the inside seal of your Frigidaire washer, model# ATF7000E. Below are instructions for cleaning the inside of your washer, including the seal:
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer, and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum. Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a nonabrasive household cleanser. This prevents dye transfer to future loads.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Affinity ATF7000E Front Load...
My plastic drum seal on my Whirlpool duet front-loading washer is chipping apart. The drum doesn't run true, is wobbly and has a rhythmic rub when turning. How do I replace the drum seal? Model GHW9100LW.
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
Maytag MAH2400A Front Load Washer
likely a rubber gasket slipped off the groove.... try taking it apart and slipping the gasket back on.
heavy loads have more force during the spin cycle.
Apr 20, 2009 | Maytag MAH2400A Front Load Washer
Wm1832cw door seal re-installation
If you haven't gotten a solution yet, I did this myself. It is pretty hard to remove the spring that is holding the gasket in place. Once you do that, just replace the gasket and reattach the ring w/spring.
Sep 11, 2008 | LG WM-1832C Front Load Washer
Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Bosch front load needs new gasket
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
291 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
