Question about Gateway Computers & Internet
No power to laptop
Just decided it wanted to shut off
  • 22 Answers
I have had same problem before - its a hard one as it could be a few diffent things.
1 - battery
2- power supply
3 - faulty ram
4 - over heating
Your 1st step would be to see if it happens again then re-post reporting if it happen when on battery or power plugged in.
Posted on Oct 30, 2008
My laptop may or may not have been spilled on and now the vga/power board is fried.
_____ w / _ \ ___________ / /_\ \_/ ___\_ __ \ / ' \ \___' ' \/ \____'__ /\___ >__' \/ \/ _________ .__ __ .__ / _____/ ____ ' ' __ ___/ '_'__' ____ ____ ______ \_____ \ / _ \' ' ' ' \ __\ '/ _ \ / \ / ___/ / ( <_> ) '_' ' /' ' ' ( <_> ) ' \\___ \ /_______ /\____/'____/____/ '__' '__'\____/'___' /____ > \/ \/ \/
Apr 26, 2012 | Dell Computers & Internet
When i power it on i get four beeps four times and it won't boot and shows nothing on the screen i.e. dark screen the make is thinkcentre lenovo model and after i decide to shut it down by long pressing...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 14, 2010 | IBM ThinkPad T40 2373 Notebook
It turns on for a few seconds then shuts off
Since you have already replaced the ac adapter. The problem is still there. the most likely cause of the failure is bad motherboard. Remove the battery from the laptop and disconnect the ac adapter . Press the power button for 10 seconds. Reconnect the ac adapter and try powering on the system. If the same doesnot work
Try the steps in the link
Thanks for using Fixya
Mar 15, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Powering down by itself. I have changed all the power options to never turn off but it still will shut down. It doesn't seem to be any time either. It can be 3mins or 30 mins. I do notice that my battery...
Remove the battery, see if it still shuts down. If it does not shut down when the battery is removed, than you can pretty much decide that the battery or the interface between the battery and the main board is the problem. If it still shuts down when there is no battery, and just plugged in via the power adapter, than it's either the power adapter, or the interface with the main board. Also, in "power options", make sure that "enable hibernation", and "standby" are NOT checked.
Jun 24, 2009 | HP Pavilion zd8000 Notebook
Laptop shuts off, and wont turn back on.
when power off, push compressed air through vent.
If you can reach fan and remove dirt,
Insist on compressed air to clean every vent.
Install temp monitor to check if CPU is getting hot.
Dec 17, 2008 | HP Compaq nc8000 Notebook
Laptop booting up and then shutting off unexpectedly.
This sounds like the cpu fan assembly go to Gateway and enter the model in the support then download the system diagram so you can remove the casing it would take me forever to type the inst. once you have removed the cover put you hand over the cpu fan assembly and check for airflow
If you are afraid to diass. your comp. take it to a pro.
Dec 15, 2008 | Computers & Internet
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
