Question about Intel D945GTP Motherboard
Intel express bios update error
Error when running bios update "unable to continue.Internal System error:There is a programming or internal problem.' My board is a d945gtp. Express bios works fine flashing the same bios I have now.
  • senddude Oct 31, 2008
    The bios update was recommended as a solution to resolve a defect in the board. that causes the cooling fan to operate at min. speed as well as gaming issues and Vista related problems.
    Thanks I'll keep looking.
    ps I have found a post that tells me it may be the smbios that is to blame?Looking at this now.
  • senddude Nov 12, 2008
    Flashed Bios from dvd Worked great.My fan issue has been resolved! As a bonus my Ram was finally recognized as 667 not 533.So there have been additional benifits in overall performance!
    Thank You All
  • 33 Answers
It sounds like you have a corrupt or wrong bios update version. If the bios update you are trying to flash is not to resolve a problem you are currently trying to overcome, it would be wise to leave it alone. Be careful or you may render your bios completely unusuable.
Posted on Oct 31, 2008
  • TF Oct 31, 2008
    Check to make sure the bios is not locked and set to "flashable." (only some boards)
    I would recommend using the bootable floppy or bootable cd method described in this document.
    http://downloadmirror.intel.com/14367/EN...
    Just make sure you are CERTAIN you have the CORRECT bios update for the SPECIFIC model and version of your MB.
    It has been my experience the bootable floppy or bootable cd methods are the best ways to flash any bios, because there is less going on between the bios and the flash software. Some manufacturers even recommend using a stripped down version of DOS to boot the computer, and then to run the flash utility from a separate floppy.
    http://www.biosflash.com/e/bios-boot-dis...
    Conversely, some manufacturers specify booting only from a Win98 or WinME bootable floopy so that the flash utility and bios signature can be copied to and executed from the RAM drive created by the boot disk.
How to UEFI mode? Based on Computers
  1. Use Device Manager's Firmware option and select Boot from EFI Internal Shell.
  2. Use the EFI internal shell, as follows:
    1. Start the EFI internal shell from the EFI boot menu and select the drive with the Windows product DVD or Windows PE. The following example assumes that the drive is Fs0:
      Shell> Fs0:
    2. Start the EFI boot application. For example, on an x64 system, run the following command:
      fs0:> \EFI\BOOT\BOOTX64.EFI For an Intel Itanium system, run the following command:
      Fs0:\EFI\BOOT\BOOTIA64.EFI
    3. After the application starts, you may be immediately prompted to press a key to boot from the drive to continue. Press a key to continue booting from the installation media.
    4. After the installation is complete, you can check whether Windows used the EFI boot environment by running DiskPart and verifying that the drive is formatted using the GPT file structure and that the ESP and MSR partitions are present.
Apr 11, 2013 | Lenovo 3000 Computers & Internet
I want to update my bios
Oh?
Kvpsy,
The information tells me;
1) Operating System: Windows XP Pro with Service Pack 3 (SP/3)
2) Processor: (CPU) Intel Pentium 4, 3.06GHz,
(Or also stated as 3.066MegaHertz) {3.066MHz}
Uses an LGA775 processor socket.
Front Side Bus = 133MHz.
(Intel processors are 'Quad Pumped'. 133MHz is the Internal Clock. 533MHz is the External Clock.
4 x 133 = 532. Number is rounded up to 533)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
Scroll down.
Prescott Core, 90nm architecture.
Pentium 4 HT model 524.
sSpec number on top of the Processor, (Heatsink removed), is either
SL8ZZ, or SL9CA
3) Motherboard manufacturer name, and model number:
Intel D101GGC
Version AAD357
3) Motherboard chipset:
ATI Radeon Xpress RC410 = Northbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges_2
IXP450/SB450 = Southbridge chip
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Southbridges_2
4) GPU: (Graphics Processing Unit, or slang = graphics chipset)
Built into the motherboard chipset; ATI Radeon 200 series with 256MB's of graphics ram memory.
(? Really? I would think more like 64MB for Integrated Graphics.
Are you running a graphics card, in the PCI-Express slot on the motherboard? Got one in one of the PCI slots?)
5) Ram Memory:
2 Ram memory slots
DDR Sdram at 400MegaHertz. Also known as PC3200.
Maximum TOTAL amount is 2048MB. (2GB)
Amount of ram memory that installed now, 1024MegaByte. (Or also stated as 1GigaByte)
960MB is what shows.
(64MB's of ram memory is being borrowed)
32MB DRAM modules. Memory module/s ('Stick') use 5 Volts (DC)
60nanosecond to 70ns, Cas Latency of 3. (CL3)
6) Harddrive:
IDE
Western Digital WD1600AABS
150GB
7) Optical Drive:
IDE (EIDE really)
Manufacturer = LG Electronics
Model number = GH22NP21
DVD burner drive
8) C-Media CMI8738 audio (Sound) chipset
9) RTL 8139 Ethernet chipset
10) Basic Input/Output System (BIOS) manufacturer = Phoenix/Award.
Version = 6.00PG
Release date = 04/20/2006
BIOS String ID = GC11010N.86A.0311.2006.0420.1525
NOW, the message you received is -
SUGGESTION: Are you looking for a BIOS upgrade?
System BIOS is more than 2 years old. (WELL NO KIDDING!!)
Video BIOS is more than 2 years old. (Yeah? AND?)
A) AS SOON as you purchase a motherboard, the BIOS program is ALREADY out of date.
BIOS upgrades are made about 2 weeks, after the motherboard hits the market.
TWO WEEKS!!
What does this mean?
It means LEAVE IT ALONE.
If everything is working OK, DO NOT perform a BIOS upgrade.
Why?
Because for;
1) IF, the power goes out to your house/business, when you are downloading, the BIOS upgrade WILL NOT be completed.
What does that mean?
Take the motherboard out of your computer, and use it for a Frisbee.
2) IF, the BIOS upgrade is too new, and/or NOT compatible, AND if you do not save the old BIOS version, take the motherboard out of your computer, and use it for a Frisbee.
IS there a cure for ruining the BIOS program in your BIOS chipset, on your motherboard, and downloading, and installing the original one?
SURE!
Take it to a PRO, who will download the ORIGINAL BIOS, to a Floppy Disk, (Or disks), using an internal Floppy Disk drive, connected with a floppy disk ribbon cable, to your floppy drive connection on your motherboard, and put it on your motherboard.
MAYBE.
(Not shouting. Illustrating a point)
OR, if the BIOS chipset is removable, (It is soldered on the motherboard), perhaps another BIOS chipset is available, for a PRO to solder the good one back on the motherboard.
You HAVE been advised.
BIOS upgrade download page,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021749.htm
Motherboard Manual,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
Regards,
joecoolvette
Jun 16, 2012 | Intel Computers & Internet
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
This program is unable to continue .the system you are trying to update does not support intel(r) express biose update or there are incompatible application running . pleade close all open application and...
Updating your bios is to risky it can ruin your your motherboard if you have mistaken to update your motherboard. Try to check your board has a newer version bios before you update it read also the how to update your bios and the problems you may encounter
Aug 08, 2010 | Intel D945GTP Motherboard
Microsoft is unable to determine the exact cause of this error. However, this problem was most likely caused by an error in your computer?s random access memory (RAM). RAM is the main internal storage area...
What are you doing when this happens? It sounds like you will have to get a BIOS upgrade weather you like it or not. Visit the motherboard manufacturer's website and obtain the BIOS update from there.
Dec 29, 2009 | Microsoft Windows XP Professional for PC
Express bios updatel won't work now on D975xbx2
try the previouse version if this message also apear to you then u must to change ur bios with new one
Jun 10, 2009 | Intel D945GTP Motherboard
D845epi Is frozen on Express BIOS Update
hold down the power buttom till the system turn off and wait for some minutes then power back on. this situations happens when you are updating an old bios.
Feb 18, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Acpi complaint - reg
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
41
Jan 17, 2008 | Intel Motherboard
Intel D945GTP Motherboard Logo
3,838 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
