Question about Carrier 38BRC048 Air Conditioner
Carrier Heating furnace
I have in my home a central Air/heater Carrier Model 58RAV095-13116 Series 130. Througout the whole summer, I have been using the aircon and it runs fine. Yesterday I turned on the heater. I noticed that the motor/blower will start and after few seconds the wire inside would glow(this unit is pilotless and does not use matches). I would expect gas to lit afterwards but it won't. The wire glow would simply die down. What must be wrong? I need help.
  • carriedaway Dec 01, 2008
    I have the exact same problem. Carrier attic, home heater.
    However, I actually had a old "bad" controller board laying around and swapped this and it lit once! but now back to no flames.
    Partitioning between the control board and the gas valve now.
    Info:
    I reset the power.
    I noticed I was getting 14v approx on the gas valve. After I let it sit overnight the valve was at 0v. ( I assume this is that safety lockout-reset thing holding 14v?)
    The last time it worked it was 0v to 24v at the gas valve. 0=Off, 24=ON
    I checked the glow filment, and the amperage was at 3.5, and it got bright orange. An article said sometimes even orange ones don't have the current and won't satisfy the control board. But mine seemed good at 3.5amps when hot. Put an amp meter on one wire to the "hot surface" ingiter/filament.
    But the gas valve isn't getting the 24 to open.and the unit stalls/stops/ LED blinks.....not sure why it hangs up with 14 or 16v at times other times it doesn't, but there's definately not 24v on the gas valve to open it.
    The fact it worked once has me confused.
    1) I assume my wiring and such is ok, as it lit once.
    2) I assume the thermostat is ok as it calls for heat and everything goes thru the cycle up to turning on the Gas valve...and it lit up once.
    I'm looking up control boards, $287. Yikes!!
    Relays are often mentioned to be sticking, and these are common and available at $2.50 each, there's only 3qty relays on the board. Potter & Brumfield Relays on my old board.. I'll try to replace all three.
    Gas Valve.. Could it burn out the new board? Most posts say this is rare.
    Any other suggestions? I'm still confused as there's a bit of programming involved too it seems. timeout, safety lockout, reset?
    Novelist:
  • 124 Answers
Either the gas at the outside valve is off, or the gas valve at the furnace may be off, or the switch on top of the gas valve in the furace may be off. if they are all on, then you may not be getting a call for heat from the stat to the furnace control board. check to see if you are getting a 24 volt signal from the stat to the w terminal and common terminal on the furnace board. if you are then check to see if the voltage is arriving as 24 volts to the wires at the gas valve itself . if it is then the gas valve is possibly bad. if it is not then the board is possibly bad.look for loose or broken connections on the low voltage wiring. most unusual that the board does everything else but send power to the gas valve. you need to zero in on the valve i think and start by turning off power and that should restart the sequence of operation and you can observe it step by step . if you are not getting a call for heat then the stat may be bad be sure you are in heat , fan in auto and temp pushed up to max. if no 24 volts is sent to furnace board white and common low voltage board then stat is bad. remove it if you think its faulty and jumper the white and red wires together on the subbase. that duplicates what the stat normally does. if the furnace lights its the stat. having said that i realize the stat has to be sending a heat signal or the other stuff would'nt start. so..... back to the furnace board. check that 24 volts in from stat and 24 out to valve and that will put you on your problem item. good luck
Posted on Oct 30, 2008
Stopped heating yesterday...fan runs, but no heat... any parts available? Pretty sure is 120v ac.
Furnace Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/furnace-problems.html
Nov 25, 2015 - If your heater doesn't heat or works poorly, this furnace repair guide will help you troubleshoot and fix typical furnace problems with step-by-step advice. ... If your furnace's motor runs but the blower doesn't move air, the belt that ..... a tune upbut couldn't really find any thing wrong . last night and today when ...
Furnace Not Blowing Air? A Furnace Troubleshooting Guide
asm-air.com/heating/furnace-not-blowing-air-troubleshooting/
Dec 1, 2014 - A furnace works by a very simple principle, it uses some type of fuel ...This series of heated coils (called a heat exchanger) has a fan ... Today we will address the most common causes of a furnace not blowing air, and what you can do tofix it. ... It seems like this would be a no-brainer, but I can't tell you how ...
Simple Furnace Fixes ' The Family Handyman
Jan 01, 2016 | Heating & Cooling
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
We just purchased a home with a beckett heater. we cant stop it from heating the house, it is 80 degrees in here and the heater is off! its burning up oil like crazy but we are only in need of the hot...
Terry, most units like yours had a Winter and Summer setting. It should be located on the furnace itself. In the Summer mode, only the water is heated for domestic use and the furnace side of the system is shut down.
Apr 05, 2011 | Heating & Cooling
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Furnace model number
I believe I have the manual for this unit. Just shoot me an email and I will send it to you. It describes in detail how to do this blower off delay.
Don,
cservice@square1hvac.com
Jul 02, 2008 | Carrier 38CKC042 Air Conditioner
Carrier 38BRC048 Air Conditioner Logo
390 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
