Pentium 4 acer aspire home edition
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
SOURCE: new acer 1641 freezes up after inserting wireless card
HI,
SOME PLUG AND PLAY DEVICES ARE NOT COMPATIBLE WITH VISTA EVEN SOMETIMES IT SAY'S THEY ARE CONTACT THE MANUFACTURER FOR AND POSSIBLE DRIVERS THAT WILL WORK WITH VISTA.
SOURCE: acer aspire e360-2b73
Mine did that too, I have sent it to Acer for Warranty Acerization, it came back in a week booting fine. Worked for 3 months and then quit again. These boards are used y other cheapos like Gateway and Packard Bell. Solution - trow away the motherboard, keep the CPU and RAM.
SOURCE: my monitor reads no signal input
Could be your graphics cards....
Was you tampering in BIOS before it started the "No Signal Input"?
If so, it'd wise to take your clock out and put it back in.
(Clock = brattrie in the PC tower, Leave it out for 2 - 9 hours maybe even a day)
