Back to:
Tags:
NetGear 802.11a, 802.11g/b Wireless Adapter
Trouble connecting to 16bit WEP network (by 3 users)
posted by anikh on Sep 13, 2006
I am using an IBMR50e laptop, running Windows XP professional. As my laptop did not come with built in wireless, I am using a Netgear WG511U adapter. The trouble is this: I have succesfully set up (in my apartment bulding, for use on 4 PC's) a wireless (11G) network using a Linksys W54GC router (currently, the network is protected by a 16bit, WEP passkey). The wireless network is accessible on all of the other PC's in my building but mine.
Specifically, here's what's going on: when I scan for the network, I see it no problem. If the security on the network is turned off, I connect and am able to browse the web. If security is ON, then my adapter still connects to the network, but when I open my browser, I get a message from my browser(Mozilla) reporting that it cannot connect to the web. Everything works fine without security, but the moment I enable the WEP password, I can no longer connect. I have verified multiple times that I am entering the passwphrase correctly -- and to make sure that I'm not making some mistake, I've tried entering the same password alternately in the "passphrase" and "manual key" fields offered to me by the network adapter software. In neither instance am I able to connect.
Here's some speculation that might help the kind soul who can assist me: when I purchased the laptop, it came with "AccessIBM" wireless software already installed. The odd thing is that I can't seem to disable the AccessIBM software (but the option to only use the AccessIBM software doesn't work, as the NetGear software needs to be running to use the NetGear adapter). I've been able to connect to unprotected networks without any problem, and I wonder if the issue with the protected network is that the AccessIBM software is somehow interfering.
Comment by anikh, posted on Sep 14, 2006
Thank you thank you -- the problem was with the length of the key that I set. Everything works now -- I sincerely appreciate your reply!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by ssammee, posted on Aug 10, 2008
Same problem - connect fine as long as not WEP can connect to other networks not WEP. What was the remedy??? ATT can't supply an answer - go figure.
Comment by garylb, posted on Dec 15, 2007
I have a netgear wg511t wireless card it connect to the network but will not connect to the internet.
If I take the card out and use the card in the laptop it works fine, I was tring to increase my speed with this card.
Clarification Request
what if it says, as netgear does, a 64 bit pass phrase????
what if the IP address returned is 192.168.x. x ????
I have the exact problem but will the remedy be the same?
Got the runaround for 2 hours from wireless providor w/out answer except we don't know but you can pay for more qualified technical help and wireless card manufacturer won't talk to me because its out of warranty - even though its not a product malfunction, just a question of configuration. Where IS customer service from either vendor? I'm so frustrataed.. I keep saying its a simple configuratation issue, it isn't a singular problem, there has got to be an answer other than someone else may be able to figure it out...
Best Solution
posted on Sep 13, 2006
FixYa! (100)
dugiehowsa
Rank:Wiz Wiz
Rating: 78%, 759 votes
On wireless networks, there are 2 stages of connecting. The first is associating with the Access Point. The seconds is properly authenticating to the Access Point. It sounds like the first stage is happening fine. The seconds stage (encryption) is where it sounds you are having the problem.
With out successful authentication in the 2nd stage, you will not be connected to the rest of the network. The reason why you cannot get out to the Internet is probably because your laptop never received an IP address via DHCP. This can be confirmed by opening a command prompt (start -> run -> Type "cmd" (No Quotes) -> Hit OK) and executing the following command:
ipconfig /all
You should have a 192.168.x.x IP address. If you have an address in the 169.254.x.x or 0.0.0.0 range, then your laptop did not receive and IP address and will not get out to the Internet.
The cause for you not getting an IP address is most likey due to the encryption keys not EXACTLY matching. This often happens when using different vendors products, as their implementations are not always EXACTLY the same.
From what you mentioned above, 16 bit WEP key does not sound like a standard length. They are typically 10 or 26 bit. What I would recommend is that you set your wireless clients and wireless router to the EXACT same settings. When doing this, do not use pass-phrases or ascii characters, as different vendors may produce different keys, and this may be causing your problem. What you want to use is a 10 or 26 character string of the digits 0-9 and the letters a-f. This is known as a hexidecimal string. This is the one sure way you will have exact matches on both sides. One example of a 26-bit WEP key would be the following:
8005532447badfad8005532447
Note: The letters can be uppercase or lowercase. Hexidecimal characters are case insensitive.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Trouble connecting to 16bit WEP network:
I don't want to Accept this solution
Can you Help with these Wireless Adapters problems?
Wireless Adapters
i had my l8400 asus notebook reformatted, now my usb port...
Wireless Adapters
my phone was originally orange and it was de chipped so i...
Wireless Adapters
please is AMBIT Modem model no J07M040.00 a wireless...
Wireless Adapters
vodafone
Wireless Adapters
enet management page is blank
Loading problems.
Repair Service
Find Wireless Adapter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
