Samsung TV PS42A57P1D Problems with colour screen is psychedelic tried resetting to factory settings but this makes no difference.
5 Suggested Answers
premtech
  • 934 Answers
SOURCE: colour problem on rear projection tv
This might be something really simple... In a large number of DPTV310 chassis, of which this TV is, the yoke connections where put in place with black electrical tape just below the retaining rings. Job is to loosen the rings, remove the tape and push the yoke back in place and tighten down retainer.. Be careful not to throw off the tilt of the yoke. The adhesive on the tape, over time, gets hot so many time it becomes slippery and allows the yoke to fall away from it's position dulling the look of the image (or focal length) causing the problem you're describing here... It also throws off the convergence - so in attempting to converge it just looks worse. Good Luck Bill
Posted on Jun 11, 2007
  • 395 Answers
SOURCE: My Sharp LCD 26" TV
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
Posted on May 27, 2008
  • 62 Answers
SOURCE: how do I reset factory settings for samsung dlp hl-5067w?
use mode button to go back factory settings its in manual page 16 and page 53 if you need manual follow this link to it http://www.samsung.com/us/support/download/supportDownDetail.do?group=&type=&subtype=&model_nm=HL-R5067W&language=&cate_type=all&mType=UM&dType=D&vType=&cttID=260039&prd_ia_cd=&disp_nm=HL-R5067W&model_cd=&menu=download&menu2=detail
Posted on Apr 16, 2009
SD Tech
  • 14553 Answers
SOURCE: red distorted color near top of screen not having
Reset will not cure a convergence problem.
this model (ws-65711) uses a single convergence chip located on the middle circuit board (see photo).
If convergence is skewed and will not adjust in customer menu the chip needs to be replaced.
Good news: I have start to finish, step by step instructions for this repair in this set. They tell you everything you will need and exactly how to do the repair.
No two sets with convergence problems will look exactly the same but I will also attach a few photos of this kind of trouble.
If the photos or what I have told you told you something you did not know and you want the instructions (free) rate this solution as very helpful as I do this here for free.
SD TECH
31e1a0a.jpg CONVERGENCE CHIP USED IN THIS MODEL.
3215424.jpgTYPICAL BOW FROM CONVERGENCE PROBLEM
ANOTHER SET WITH CONVERGENCE PROBLEMS
Posted on Sep 14, 2010
Testimonial: "This seems to be the problem I'm having Tks for the information great help look forward to getting your instructions to replace the chip. "
Samsung tv smart hub picture problem
I will try to update the TV firmware first, you may log on Samsung support webpage to check is there a firmware update for your TV model & update it.
Also, you may go to the on screen menu to reset the TV to factory default to clean up the internet data buffer.
Jan 14, 2018 | Samsung Televison & Video
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
Why does my Westinghouse 32" flatscreenTV shows fuzzy psychedelic colors
Have you tried resetting the TV's settings to the factory default?
You should be able to do that within the settings menu on the TV.
May 01, 2014 | Westinghouse LTV32W6HD 32 in. LCD...
Sony bravia problems....intermittent fault. Colour turns psychedelic. Looks like TV is "on acid"!! Sometimes TV can run normally for several hours before the colour fault occurs.
You have a defective T-Con board. The small board near the top center of tv. Can not give you the part number without knowing your TV model. Depending on model $50-120 for part.
Apr 16, 2014 | Televison & Video
Screen display all mixed up colours on samsung tablet
Could be a number of problems I would take it in and have it bench tested.
Terry
Mar 09, 2014 | Samsung Galaxy Tab 4G 10-in 32GB White...
No color on samsung lcd tv even after factory reset
hi if you bring the menu up and it's clear then you have a tcon board fault, if the menu is the same as the picture then you have a mainboard problem, thanks
shaun
Mar 09, 2017 | Samsung LE40R73BD 40 in. HD-Ready LCD...
We have a samsung 47'' projection tv approxiimately 7 years old. There is a colour issue with the tv where we have a shadowing of objects and words. We have navigated to a screen with the original remote...
Try unpluging set from the power source for 1 plus minutes then restart. If there is still problems make sure you have your owners manual and are following proper procedure and using the factory remote. good luck
Jun 20, 2009 | Televison & Video
Colour problems
try to go in menu do factory reset ok
Feb 03, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
