Question about Whirlpool LER4634J Electric Dryer
Maytag Gas Dryer - Shuts off before clothes are dry - was cleaned ?
Hi -- first of all, I'll say that I'm NOT the most technically inclined person (nor is my husband).
A few months ago he had to replace the dryer vent hose (?). Oh brother.
He ended up doing a slap-dash job ... and put a couple of holes in the wall too. BUT THE DRYER WAS WORKING FINE.
About a week ago he came home with a new metal vent, some tape, proper tools, etc. Cleaned out the lint from the back of the vent and put a new vent pipe in the wall (apparently the one that was in there was short - only stuck out about an inch from the wall, very hard to attach vent pipe/hose to dryer).
Then I looked on-line and found out how to take the front off the Maytag Gas Dryer. (use a putty knife to pop the top, and then remove the two screws).
OMG!! Dust bunnies from Hell! Lint - packed around the blower and everywhere. I clean my lint trap after EACH load, but the inside of the dryer was a mess. So I cleaned it out as well as I could.
I'd like to know how to take the lint screen area COMPLETELY off the door, so I can really get down into the area to clean it.
But here's the problem -- NOW THAT IT'S CLEANED OUT - IT DOESN'T DRY THE CLOTHES! I have to run the dryer 2 or 3 times because it shuts off before the clothes are dry.
Also I noticed that sometimes the outside of the dryer feels REAL hot, and other times just warmish.
HELP!!!! What's wrong?
    Sergeant:
    Champion:
  • 324 Answers
Check to make sure no "dust bunnies" got inside you vent hose blocking air flow.
Posted on Oct 31, 2008
Maytag gas dryer not drying cloths
Here's an idea, is your machine in a well ventilated area? Gas powered devices have oxygen sensors that detect when the oxygen level drops to a dangerous level, this shuts off the gas, but not the machine. Put a fan in the room, open the window or door and try again.
Dec 29, 2013 | Computers & Internet
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Currently the dryer is not drying clothes at a great rate of speed. The heat is on but it is not enough to dry the clothes in a timely manner. Please help me with a solution, I really enjoy the Maytag...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 08, 2011 | Maytag Neptune MCG8000AW Gas Dryer
I have a Maytag dryer MDG6200AWW and at first the machine dried the clothes fine but never shut off. The second load got hot but not long enough to dry whole load. The timer does not advance at all. ...
Remove the front panel to get to the gas valve. To remove the panel remove both screws holding the door hinges and the screws on the opposite side from the hinges across the door opening.
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Aug 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Oct 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer MDG5500AWW will not heat. Tumbles but no heat.
Could be any number of things .. igniter ( which lights the fire that dries your clothes) over-temp switches ( that disable the gas valve from opening and won't let a fire get started..) Defective gas valve.. not opening to let gas in for the fire that dries our clothes..
Those are the main components in your system and not much more I can provide to you unless I had specific details on what you've checked etc.. maybe this link will help identify the parts associated with your dryer... and if your so inclined..can do your own diagnostics... http://www.pcappliancerepair.com/model-display.php Hope that helps...
Aug 24, 2008 | Maytag Dryers
Whirlpool LER4634J Electric Dryer Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
