Question about KitchenAid KSM150PS Artisan Series Stand Mixer
KitchenAid Artisan 10 speed 325Watt Mixer
The mixer attachment head does not rotate when the mixer is turned on yet the motor is running...it seems to have uncoupled from the drive belt or gears?....If I push up on the shaft it will catch and turn about on half rotation and stop...Is this a easy fix for this DIY guy or do I have to bring in for service....Thanks
    Problem Solver:
  • 16 Answers
Be sure the gears mesh fully with your repair. There is a mechanical fuze; a single plastic gear engineered to control damage in event of physical overload from overmixing heavy batter or dough & overheating it causes, use of wrong mix accessory for the batter, slamming into high speed from a stop, mixing real marble into marble cake, etc. These loads can cause bushings in the worm gear assembly to shift so that part of the worm gear runs above the double gear with which it meshes. This mis-mesh match reduces the load the gears can carry so that metal gears break if the mixer becomes heavily loaded again. Locating dowells pretty much assure the gears teeth mesh to proper depth automatically- its the vertical alignment at issue. Special fibre shims, not mere fiber washers, are used to realign; they properly resist deformation and wear.
Also look out for bent or broken dowell pin retatning the large doublegear on the propeller shaft. (the agitator shaft holds the beater, has similar dowell)
Note that the KitchenAid grease is food-grade with no known toxic effects- substitute at your peril.
Posted on Oct 21, 2011
  • 421 Answers
Hi, The KitchenAid mixers are usually quite easy to work on if you are competent at DIY. It sounds like a gearbox fault. Gearbox parts are easy obtained for most of the models and are easy to repair.
This is a service manual for a lot of the KitchenAid mixers. Might give you an idea on how difficult it is to work on before taking the plunge.
Hope this helps
Posted on Nov 15, 2008
What is the rpm of artisan 300watts
On low speed roughly 1 rotation of the planetary per second. On high speed it should be the maximum speed that motor can run at, too fast to count that's for sure.
Oct 05, 2015 | KitchenAid KSM150PS Artisan Series Stand...
Motor not turning on
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Make sure that the Motor Brushes are not worn out and making good contact with the Motor.
Adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 15, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Mixer has lost all speeds, only works when moving the lever back and forth. The mixer is about 9 years old.
Adjust the mixer speeds:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 14, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
First, you may want to adjust the mixer's speeds:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 14, 2011 | KitchenAid K45SS Classic Stand Mixer
Motor does not start until switch is in 4-5 position, also the arm does not turn.
It looks like you may have two different problems. First, you must adjust the mixer speeds.
Second, if the motor runs at different speeds but the Planetary Assembly does not rotate, then
you may have a stripped Worm Gear Follower.
The K5SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 23, 2011 | KitchenAid K5SS Heavy Duty Commercial...
The head of the mixer seems to dip to deep into the bowl. It is scraping the bottom and chipping the attachment.
Hi, Put your mixers head in upright position and adjust the screw between the head and the stand. This will rise the head (one rotation is about 1 mm) and the attachement will not scrape the bowl.
Jun 30, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I have to physically hold my Artisan mixer in place or it will go off the counter, even at low speeds. Seems to rotate fine as long as the head isn't down with an attachment on and in the bowl.
I think from your description that the the head connecting to the base shaft needs tightening. Put the mixer on it's side. Look up inside the base and you'll see a small set screw.
With a flat blade screw driver tighten that screw and it should stop moving. If it doesn't you probably need another shaft because it's worn.
May 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen Aid 10 speed 325watts
Some of the gears may have broken or slipped off. You'll need t open it up to see why the shaft from the motor will not spin or you will burn out the motor with the power on trying to make it go. It might be a DIY job if you can see an obvious problem like a slipped gear, otherwise take it to a repair specialist.
Apr 30, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
449 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
