Question about HP iPAQ H4355 Pocket PC
Don't know the steps to connect to wireless in home internet with HP 4355 pocket pc. It says I'm connected to my wirless router, but I can't get internet access.
  • 1 more comment
  • fokker101 Mar 11, 2009
    I have a similar issue. My ipaq 4355 will not connect to the internet at work. We have wireless access available to the public. My ipaq will actually say its connected to the available network, and I will get to the web page where all users have to click an 'accept' button to agree to the terms of use. MY ipaq just reloads the same page with the 'accept' button each time I click it. If I try to load other pages, is says they are not available. However, if I put my ipaq in the cradle that is connected to my pc (which is connected to the network), it will get to the page with the 'accept' button, and when I click the button, it also reloads the same page with the button again. BUT, if after that I type in another website, such as google, it loads fine and I can browse the web just fine. I want to be able to browse the web without being connected to the cradle. Also, I have the following updates: DSTfixsp34881.exe, Pocket PC 2003 terminal services client workaround (SP27473).exe, ROMandBIOSUpdateSP28375.exe, and WirelessUpdateSP28733.exe. Any ideas or help would be appreciated.
  • fokker101 May 11, 2010
    the Ipaq will also connect fine to my wireless network at home, which is secure.
    There is no wep key reqiured for the public access.
    Master:
  • 409 Answers
Have you entered the WEP key?
Posted on Oct 30, 2008
Can not connect with my home computer.Router and modem working,just won,t connect
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 14, 2010 | HP Pavilion dv6000z PC Notebook
Wireless Connection to the Internet
Hey mate,
So looking at your pda - it has no wlan build in, so you would need to get a wireless adapter for it.
Its pretty simple, install the adapter, plug it in, setup the wireless details of your home and your set to go.
Jul 03, 2008 | Matsunichi i-mat IP3230 Pocket PC
My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Apr 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have cricket broadband wireless internet, how do i set up my belkin wireless router to it so i can send out a internet signal to another source?
You cna get the router manual on the below link free link
http://dl.owneriq.net/8/81c69071-e6b4-da74-6921-04cb37aa97a5.pdf
Also you can follow the below steps to set it up
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
Let me know if this will help
Regards
Dec 04, 2009 | Computers & Internet
I bought acer one mini laptop if i have to connect wirless internet what i have to do do give me the step by step instruction how wirless internet works faisalhasib@hotmail.com
How you connect depends on where you are connecting to.
If you want to connect to your existing internet at you house you will need to purchase a wireless router and connect your dsl or cable modem to your router. You will then have a wireless connection in your home.
If you are talking about connecting to a public wifi connection (like at Starbucks) you will have to be within range to get a signal. If you are at your friends house and they have an existing wireless connection that is secured you will need the access key.
Once you are ready to connect you will need to decide how you want to manage your wireless connection. Usually your wireless cards include software to manage your connection. If you do not have the software or you do not like the software Windows can manage your connection for you. To enable this service you will need to open control panel and then open administrative tools open services and scroll all the way to the bottom and click on wireless zero configeration change startup type to automatic. This shoulbe the only time you have to manually configure this service.
After you choose which program to use for your wireless connection open it and you will see available wireless connections click connect on your desired connection and you should be on.
Oct 29, 2009 | Acer Aspire One PC Notebook
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
I'm trying too connect to internet/
This depends if you connect with an ethernet cable or wireless connection. With the cable, just plug into your modem or router. If wireless, then you need to set up the wirless connection on your computer.
Dec 26, 2008 | Computers & Internet
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
Need help
you reaqaly dont nned to pay for anything just get internet connection via wirless network (linksys,wireless router). that gives you wireless internet for computer, video game consoles and more. the router is bout 60-100 dollarz
Feb 18, 2008 | Nintendo Wii Console
SSID and WEB KEY number
i WANT TO CONNECT MY PS3 USING MY WIRLESS ROUTER BUT DON'T KNOW HOW TO CONNECT IT CAN YOU HELP
Jan 04, 2008 | Linksys Wireless-G Broadband Router
HP iPAQ H4355 Pocket PC Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
