Question about Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference
PLEASE WAIT.... not responding to reboot
The Please Wait..... signal is not responding to phone / diagnostics / reboot.
  • holt123 Dec 05, 2008
    Attempts to register, but ends up failing after 5 or so minutes. There is is signal coming from the base station.
  • 4 Answers
Try registering the base station to the console. Press Menu, then admin setup, then registration and follow the prompts.
Posted on Nov 19, 2008
My panasonic kx-fl501 fax message says please wait and the keys don't work
I realize this thread is old, but I just encountered the same problem with my Panasonic KX-FL501. Pressing #9000* does not work, as none of the key pads are responding. When I lift the receiver I get a tone. But the keys don't respond when I dial. Display shows "please wait"..... I've been waiting for hours.
Feb 08, 2012 | Panasonic KX-FL501 Plain Paper Laser Fax
I can not call neither receive and there is a tone
If you're a problem in making calls and you're hearing a beeping sound or tone then ill be advising you to please check the signal bars on your phone because it might be that you don't have a good reception that's why you cannot make a call. If you have signal bars but you cannot make a call then you can try rebooting the phone and you can do that by removing the battery while the phone is on and then wait for 15 seconds, after that reinsert the battery and turn on the phone again and then try to make a phone call. You can also check if your phone has enough balance to make a call.
THANKS!
Apr 20, 2011 | Cell Phones
I cant make calls
If you're a problem in making calls then ill be advising you to please check the signal bars on your phone because it might be that you don't have a good reception that's why you cannot make a call. If you have signal bars but you cannot make a call then you can try rebooting the phone and you can do that by removing the battery while the phone is on and then wait for 15 seconds, after that reinsert the battery and turn on the phone again and then try to make a phone call. You can also check if your phone has enough balance to make a call.
THANKS!
Apr 17, 2011 | Cell Phones
I get no ring-signal when I have an incoming call. When I try to choose signal in the menu the phone restarts.
hi,
your phone have a software problem, it will fix by a certified technician in nokia care center by programming it...just pay a little amount of money..but wait ,i have a solution to that you can also fix that without spending a single cents and leaving your home...
procedure...
1.in your phone,go to menu
2.)settings
3.)restore factory settings
4.)enter your security code
5.)wait until your phone reboot..
test the phone ,go to tone settings and choose the ring tone you want..
i hope it will help you ,tested in my cellshop many times...
Jun 19, 2010 | Nokia 1661 Cell Phone
My samsung u600 has stopped sending texts for the second time in 2 days. When I try and send one the screen freezes and the phone then reboots itself and says ''please wait'' and says it's initialising sms...
restore your phone or do a full EEPROM Reset using this code.*2767*3855# and wait till reboot completely done.be sure to have enough battery life before resetting EEPROM.
Jul 22, 2009 | Samsung SGH-U600 Cellular Phone
"Please wait" (rebooted, then) "searcing for signal"
Sounds like the base station and console are no longer registered to each other. Press the menu key, then admin setup then registration. Follow the prompts to register the base with the console.
Oct 01, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Sorry! my it be posible to help samsung shg t219 after unlock at top screen shows locked signal and searching signal not getting. Regards abdi
put in the sim card that the phone is not meant to work with
enter
*#9998*3323#
press exit
phone resets
wait for the phone to reboot
& the phone will work with the new sim
your problem will be solved
any doubts reply me
i am always here to assist you
thank you
bye
please rate my solution
Jul 02, 2008 | Samsung SGH-t329 Cellular Phone
Polycom soundstation 2W
I went to Admn Setup to reboot the system from Please Wait.... & it doesn't work!! Best Solution posted on Sep 19, 2008 2%20stars.png
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Just had this problem with the 'please wait' - go into the admin setup and select Reboot Phone - it then works!
Jun 23, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Please Wait....
push 1.4.and 9 all same time . i read this post some where and it worked great
Jan 08, 2008 | Polycom SoundStation 2W (2200-07800-001)...
LG RH1999H DVD Recorder
I did try removing the Hard Disk from the recorder and did a diagnostic and fix-disk using Ontrack software. Ontrack showed no structural and physical defects on the hard disk. I replaced the hard disk in the recorded and guess what! Please wait, please wait, please wait, please wait...................................
Nov 06, 2007 | Televison & Video
Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference Logo
1,171 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
