Question about Aiwa CDC-Z137 CD Player
No sound Hi, Everything works on my Aiwa CDC-Z137 with the exception of - I have no speaker output. I have a second unit that I could take a part from if necessary, but I don't know what part to swap out, or what could be wrong. Thank you so much for your help in advance. TJ Rouser
  • obtoonse May 13, 2009
    i have the same problem
5 Suggested Answers
SOURCE:
imseth85
  • 30 Answers
SOURCE: aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Posted on Mar 31, 2008
  • 95 Answers
SOURCE: no sound from my car stereo, a aiwa cdc-z137.
Doudle check rca's. Also check the setting in the menu browers. Make sure the mute overide is not on. Not sure if your model has it but is very common, and overlooked
Posted on May 13, 2009
  • 52 Answers
SOURCE: I need a user manual
A pdf version of the manual can be downloaded from the link below. Scroll down to the bottom of the page and enter the code and select "download." Once you select download it will make you wait 30 seconds, but it will start after the time has elasped.
http://www.nodevice.com/user_manual/aiwa/cd_receivers/cdc-z137.html
Posted on Apr 17, 2011
SOURCE: Aiwa cdc-x317 will not eject
Somewhere on the front of deck there should be a small pinhole just big enough to fit the tip of a pen push it in either pen or Sharp object. It should force it out.
Posted on Sep 11, 2011
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
I need a user manual for CDC-Z137. I don't know how use AUX and time setup.
Apr 17, 2011 | Aiwa CDC-Z137 CD Player
I just got the aiwa cdc-x227 and the mute is on.how do you unmute it?
check for a logo that shows a speaker with a cross(X) across. just switch this back. this is also available on the remote. You could normally find this on the top side so as to mute easily when in a traffic junction. Check if this button is jammed. Also check if the display shows a mute , if not the sound reduction could be a different issue related to the audio output. check if any speaker connections are short, or speakers connections touching the body. Chek on the wiring once again with a multimeter , for any shorting, correct positve voltage and good ground. hope this helps. Good day
Jul 07, 2010 | Aiwa CDC-X227 CD Player
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
No sound from my car stereo, a aiwa cdc-z137.
May 13, 2009 | Aiwa CDC-Z137 CD Player
Aiwa CDC-X207
hi yellow go in left bottom corner
Jul 12, 2008 | Aiwa CDC-X204 CD Player
Aiwa fm/am compact disc player cdc-x304 face plate
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Wiring problems
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester as against the ground/body of the stereo unit. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Aiwa CDC-X155
Aiwa CDC-X304
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=418
Aug 06, 2007 | Aiwa CDC-X204 CD Player
Aiwa CDC-Z137 CD Player Logo
26 people viewed this question
Top Aiwa Car Audio & Video Experts
Kitte Ka'at
Level 1 Expert
Joaquim Martins
Mike Duncan
Mike Duncan
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
