SOURCE: My Canon copier, Model IR 400s, Shows the error
hi sir my xerox machine IR 400 the error code e0110
SOURCE: 051 code showing in gp 405
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
SOURCE: CANON GP 405 ERROR E 051
hi
horizontal registration home problem sensor(ps14),motor,dc controller
SOURCE: E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
E805 (The fan rotation is faulty.)
If no detail code is indicated,
suspect the feeder fan (FM1) or the
reversing guide cooling fan (FM9).
Is the connection of these fans
normal? Is the drive signal of the fan
identified in the previous step about
22 VDC while the fan is rotating orabout 12 VDC otherwise?
That is one side with the fans,
Secondly, if the fans are found right, then for sure you need to change the DC Controller.
Regards!
Originally Posted by logimix
Could somebody tells me... what this error (E805 - Canon GP 405) is... and how to resolve it? thanks a lot. john pl check detail code after 805 .Fan related fault. Also power supply(composite)
