Question about Compaq iPAQ PCD-1 Personal CD Player
My pcd-1 got problem! help!
Hello! May I ask a question? My pcd-1,after pressed the power button,the flash logo diaplayed,and then "reading risc",and no response with any button.I have checked the quartz's wave of CPU(cxp83512) and MP3 decorder(320v5614),they're all OK! and the reset circuit of cpu was good.so I have no idea now,can you help me?
antiochpc
  • 1314 Answers
SOURCE: Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Posted on Jun 21, 2007
artifixit
  • 59 Answers
SOURCE: monitor
The power supply in this monitor has probably failed, but since HP doesn't stock spare parts for their monitors you will probably need to replace the whole monitor. HP only does full unit replacements on their LCD monitor range.
HP also doesn't provide any electronic schematics so getting it repaired will be difficult.
Posted on Feb 11, 2008
  • 700 Answers
SOURCE: Pc keeps shutting down when trying to power it up
Hello, its the same thing. Almost everytime when I clean my desktop of dirt and the memory stick got moved. When I power up the unit and only the fan and led comes up.
My first suspect will always the memory. I will just make sure to clean the memory connector using pencil eraser method., reseat and power up again.
In your case I suggest to clean its connector to free it of dirt (varnish like coat on the memory connector). If it still freeze, check the memory if one is already failing.
Posted on Mar 28, 2009
sodeep
  • 3267 Answers
SOURCE: cpu not powering press on button lights flash fans turn for a sec
It a issue with the power supply or the SMPS. Change the SMPS of same capacity and then it should work..............sodeep
Posted on Jul 30, 2009
  • 45 Answers
SOURCE: Evo starts green light turns red no response
open the machine up and locate the BIOS battery. it is a small round flat battery. take it out for 20 mins and then put back in and try starting up again
Posted on Aug 07, 2009
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
My virgin mobile is stuck on the main screen
Hey,
Turn off the phone. While the phone is off
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note: You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note: The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
Mar 31, 2013 | Virgin Mobile PCD Venture No-Contract...
Flashing LG logo
Hello My Dear Costmour:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 28, 2012 | Pantech Cell Phones
I am using a MS-6309 N1996 Ver 1 motherboard...how do I get into BIOS? I changed my hard-drive and now the screen eventually goes black at power up and a cursor flashes. I tried the 6 floppy discs initial...
Hello, you usually press 'delete' or maybe the tab key on power-up. Try and read the message that will flash up on the screen, usually momentarily, just before it starts to boot. Instead of powering down then back on, press your 'restart' button then you might see the messages that you may have missed if your monitor was still warming up. Regards, nicam49
Jan 22, 2011 | Intel Motherboard
I have not droped or no water damage.just flashes all the time when on charge but does not charge watt can i do please.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 25, 2010 | Apple iPhone Smartphone
My touch can't touch for some reason, nothing works when i toch the screen
Hello there,
Your ipod must have been frozen. While the ipod is turned on, press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  • Step 3 Power on the iPod Touch.
  • Step 4 Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  • Read more: How to Restore an iPod Touch | eHow.com http://www.ehow.com/how_2249655_restore-ipod-touch.html#ixzz0tg6tAehJ
    Jul 14, 2010 | Apple iPod touch
    Iphone 3g 3.0 stuck on iphone apple logo loading screen
    2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    More resets:
    Try This:
    1. Remove Sim Card
    3. Replace Sim Card
    Also, Try this:
    2.) Start up iTunes
    Aug 27, 2009 | Apple iPhone Smartphone
    Xerox Phaser 8500
    Entering Service Diagnostics without Rebooting the Printer:
    This method of entering diagnostics is to allow customers to be diverted to service
    diagnostics in order to perform some tests.
    1. Display the Hidden Service Menu as described in "Hidden Service Menu" on
    page 4-2.
    2. Scroll down to Enter Diagnostics and press the OK button.
    Entering Service Diagnostics by Rebooting the Printer (8400):
    1.
    Turn the printer power OFF.
    2. Press and hold the Back and Help buttons.
    3. Turn the printer power ON while continuing to hold the Back and Help buttons
    for approximately 30 seconds until the Control Panel indicates Diagnostic
    Menu
    Entering Service Diagnostics by Rebooting the Printer (8500/8550):
    1.
    Turn the printer power ON.
    2. Wait for the Xerox logo to begin moving across the display.
    3. Before the logo is centered on the display (stops moving), press and hold the
    Back and Help buttons on the Control Panel.
    4. Hold both buttons until the display reads Beginning Service Mode
    Initialization
    . Release the buttons and the printer reboots into service mode
    with the Service Diagnostics menu displayed.
    May 23, 2008 | Xerox Phaser 8500/DN Printer
    37 people viewed this question
    Top Compaq Audio Players & Recorders Experts
    Jerry Greenberg
    Jerry Greenberg
    Tom Chichester
    Are you a Compaq Audio Player and Recorder Expert? Answer questions, earn points and help others
