Using HpDeskjet f2280 All-In-One Printer, Scanner, Copier. When scanning have error message "Internal DRS Error 1500:c0:3001
  • 10 more comments
  • Anonymous Oct 31, 2008
    internal drs error hp
  • aborel Nov 01, 2008
    same
  • bfry Nov 09, 2008
    Error: "Internal DRS error 1500:c0:3001" occurs when saving a scan to a PDF file. Using Vista and a Photosmart 3210xi. Scan appears to complete correctly and displays on the screen. It's only when it saves the scan to a .pdf that the error occurs.
  • newenglandre Nov 19, 2008
    have you figured out the problem? my HP c6180 does the same thing. I have uninstalled and reinstalled the software, updated Adobe and tried HP support with no results.
  • adrianniszcz Nov 20, 2008
    The same error with saving to pdf file
    HP DeskJet F2280
    Windows Xp SP2, drivers from CD
  • Anonymous Nov 23, 2008
  • jfr23236 Dec 11, 2008
    Error: "Internal DRS error 1500:c0:3001" occurs when saving a scan to a PDF file. Using Windows XP and a Photosmart 6280. Scan appears to complete correctly and displays on the screen. It's only when it saves the scan to a .pdf that the error occurs.
  • bob6610 Dec 19, 2008
    Using HP F2290 with HP Compaq nw9440 laptop. When scannng document with OCR to Word or PDF. Scan goes file but when OCR start to work on scanned image I get Internal DRS error 1500:c0:3001. Have tried reinstalling printer software to no avail.
  • tvk1954 Jan 08, 2009
    exactly the same problem with my HP Deskjet F2235
  • jww273 Jan 08, 2009
    I have the same problem with my F2210.
  • skwiza Feb 20, 2009
    Using HP Deskjet F2280 All-in-One to scan documents, I get the following message:
    Why & how do I fix?
  • alibundy2003 Mar 11, 2009
    i have the same problem too and i dont know how to change the resolution to 200i. can some one help me out
You need to change the resolution on the scan to 200 dpi. I submitted this to HP and that is what they told me to do. It works. The steps to do it vary according to your HP Solution Center software version. Just find the "Scan to PDF" settings. In my case, I had to create a new "default" profile because it wouldn't let me modify the installed setup without saving it under a new name.
Posted on Jan 09, 2009
I have the same issue and changing the language as one person suggested on another board, or changing the dpi to 200 only made little squares behind all the letters.. :( Hope HP has a fix for this, it's VERY IRRITATING when you are using the scanner for work.
Posted on Dec 17, 2009
When I try to scan a document wth HP all in one 4355 I get a message "internal DRS error 1500:c0:3001" and the scanning fails. Please find a solution
Posted on Aug 26, 2009
My hp deskjet f2280 printer does not photocopy. It displays an "E" error message, always.
I have got exactly the same problem. E shown. F2280 does not copy. Otherwise it prints and scan request from PC working.
I do hope, somebody reads the question, understands what is said and has a solution. Thanks in advance. AOS
Jan 23, 2011 | HP DeskJet F380 All-In-One Printer
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have an Officejet 5610 All-In-One and when I am trying to scan, while processing, I am getting "Internal DRS error 1500:c0:300". How can I solve this please?
Search the HP knowledge base for more ideas. You didn't say if that error message is showing up on your computer or on the LED panel of the printer.
Sounds like your trying to scan a document. Make sure the application that is supposed to receive the document is installed.
Oct 10, 2009 | HP Officejet 5610 All-In-One InkJet...
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage:
http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Success!
Aug 28, 2009 | HP LaserJet 3600n Printer
HP deskjet f2280 won't scan
you can try clicking MY COMPUTER then C: then PROGRAM FILES then Hp then Destination folder then bin then find the hpscnapp with a printer icon.Scan will work.Hp 2280 frequently encounters error especially if you're using VISTA. Hope i helped! Good day!
Aug 04, 2009 | HP Office Equipment & Supplies
I'm getting a error that states.Internal DRS error 1500:c0:3001 after scanning a document while I am saving it.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd3
Apr 21, 2009 | HP Officejet 5610 All-In-One InkJet...
Internal drs error 1500:c0:3001
Try change the OCR language.
I had the same problem (HP Deskjet F4280, error code 1500:c0:3001) scanning documents with danish language to PDF and OCR language set to English. Changing OCR language to danish solved the problem.
PaulPS
Apr 13, 2009 | Office Equipment & Supplies
I'm getting an error:Internal DRS error:1500:c03001.PLEASE HELP!
You need to change the resolution on the scan to 200 dpi. The steps to do it vary according to your HP Solution Center software version. Just find the "Scan to PDF" settings. or create a new "default" profile because it wouldn't let you modify the installed setup sometimed without saving it under a new name.
Apr 13, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Computers & Internet Logo
5,132 people viewed this question
David Payne
David Payne
