Question about Compaq iPAQ H3955 Pocket PC
How to fully reset my 3955 ipaq pocket pc
I got ipaq 3955 pocket pc, i could not display the normal screen only thing shows on the screen is align screen, it tells me to tapp the screen to set the pc, i have done several screen tapping to get the alignment but nothing happens. Anyone can help me would be greatly appreciated. Thanks
  • khore187 Feb 22, 2008
    same thing happens too me
  • Compaq Master
  • 13,433 Answers
Posted on May 19, 2008
  • Ekse Jun 01, 2008
    This thread has gone 7 days or more without a response. Please close the thread with a “FixYa” or “Helpful” rating.
    If the issue is not resolved, please post back with latest developments, what steps you took, etc. and I will assist you further as best I can.
    Thank you.
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
SD card not recognized on ipaq 3955
your machine's scan disk drive could be getting old and not work i think your best bet is to buy a new one or replace it.
Feb 26, 2009 | Compaq iPAQ H3970 Pocket PC
I can't make my IPAQ pass the align screen
Replaced LCD touch screen in Australia.  Cost $95.00 AUS Thanks for Fixya help you where really great.
Feb 12, 2009 | Compaq iPAQ H3955 Pocket PC
I have a hp Ipaq h2200 pocket pc
Hello :-) I have a Ipaq 4350 and the same thing happened to me. one day I hard reseted it and when it came to the point when it asked me to align the screen it froze and wouldn't move at all. I found out that it was screen that got damaged somehow. And I think your screen is damaged too. I'd recommend calling HP.
Apr 10, 2008 | HP iPAQ H2210 Pocket PC
Stuck on "align screen"
your touch screen gone just change your touch screen it goes back to normal
Mar 20, 2008 | HP iPAQ H6300 Pocket PC
HP iPAQ h3615
It is a standard feature that after every hared reset , you have to reset the ipaq. So just follow the instructions which will lead you to reset it. first tap the screen at the point where two lines cross, then repeat it as it asks you to do.
Aug 13, 2007 | HP iPAQ h6315/h6365 Pocket PC
Hard reset does not wok in my ipaq H3955
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Sep 14, 2006 | Compaq iPAQ H3955 Pocket PC
IPAQ 3955 Won't Sync?
Try uninstalling, rebooting and reinstalling ActiveSync on the host. If you haven't yet upgraded to 3.6, maybe upgrading will clear up the problem.
Sep 12, 2005 | Compaq iPAQ H3955 Pocket PC
Compaq iPAQ H3955 Pocket PC Logo
224 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
