Question about Refrigerators
Whirlpool ED22DWXTN00 Ice maker
The ice maker on our unit has stopped making ice. My husband checked the hoses on back and did not see anything. Where should we start?
Sherri
  • 59 Answers
First off is the ice maker still cycling? If it is you should check the water valve. If not first pull off the white cover on the ice maker and check the pins in the middle of the cog wheel.Whirlpool ED22DWXTN00 Ice maker - 879aba8.jpg
If they look smashed or broken you need to replace module. (part# W10122536) if that looks fine you'll need to delve deeper. There is a thermostat in the ice maker that controls its operation. If you can get a wire about 3in long and bend it into a U shape. Then insert it in to the "T" and "H" holes on the module.
Pull them out after about a 30 sec count. If the ice starts cycling then you need to replace the thermostat. (Part # 627985) if it doesn't cycle then the motor is probably bad and you'll need to replace the module. Hopes this helps and if you need more help or clarification then let me know. Good Luck!
Posted on Nov 02, 2008
Ice maker stopped making ice water leaks from the device used for getting ice cubes
you need to replace the water valve (usually Blue) 0n the back of the unit as its stuck in the open position shut the water inlet before you disconnect anything.
Jun 16, 2011 | Whirlpool Refrigerators
hi,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Oct 03, 2008 | Whirlpool GS6NBEXR Side by Side...
I have the Whirlpool gd25dfxfw02 and my freezer stopped making ice. I tried to fudge around with the silver lever/handle and stuck it back in the hole, put the lever down and it still hasn't made any ice....
1.Check shut off arm struck due to stored ice in bucket are too much. Clear it.
2.Check water pressure is normal.
3.Check freezer temp. Must be 5 degree and less.
4.Check water hose to Ice Maker. No leak in hose.
Hope helpful?
Jan 28, 2011 | Refrigerators
I have a Whirlpool Gold GD22DFXFW02 side by side fridge/freexer with ice maker and water dispenser. Besides the fact that the water dispenses very slowly, the ice maker has stopped making ice. It appears...
Sorry to read about your problem, I hope this helps you out.
yes no water to the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Whirlpool Refrigerators
My ice maker stopped making ice...is there anything i can check myself to correct this problem
If the ice maker has completely stopped producing ice :-
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly:-
Check this link for your knowledge:-
http://www.partselect.com/refrigerator+icemaker-no-ice+repair.htm
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped making ice, it just stopped. There is nothing blocking the outlet, no debris. The water dispenser still works fine but the ice maker is not working. I have a whirlpool 2665 refrigerator....
your ice maker unit is gone bad if you have warenty get them to replace the ice maker if not you need to do it :(
its coast +- 120$ :(
911service today . com
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool GS6SHAXML side by side refrigerator not making uce
check the filkl tube it may be frozen up due to a leaking solinoid valve.
Apr 06, 2009 | Whirlpool ED0GTQXMQ Side by Side...
you could jumper holes L and V with a 14 gauge solid wire for 5 seconds to start it.
Nov 06, 2008 | Refrigerators
Whirlpool side by side icemaker won't stop... lol
no you shouldnt have to replace the ice maker, the stop arm probably is not in place. pull the ice maker out and check where the arm goes into the motor head. I think that will solve it for you. Good Luck.
Sep 28, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
164 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
