Question about Jenn-Air JGR8875QDS Gas Kitchen Range
F-14 I have a Jenn air gas range oven model number jgr8875qd i've owned it since 2005, about a year ago the oven would not heat when turned on and i had it repaired, and it worked fine until a month ago. Now it acts as if posessed. Beeping for no reason, the stove still works however the panel that contorls the oven does not react to being touched. the clock still works. when i called the company they told me to hold down certain buttons to make sure it is not locked. the off- lock flashed across the screen and nothing changed. then i as i have on multipule occasions cut the power to the unit. this last time however f14 flashed across the screen the woman on the phone tols me i must have a certified repairman look at it. Honestly i can not afford this, i am looking for suggestions as what might be wrong. thank you for your time!
5 Suggested Answers
  • 26 Answers
SOURCE: Jenn-Air electric range
I believe f3 means a bad oven sensor
Posted on Jan 09, 2008
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
  • 16 Answers
SOURCE: Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
You need to replace the Clock Board when that happens. It will probably be about $100 or less.
Posted on Jul 06, 2010
KevinWhite
  • 1902 Answers
SOURCE: Jenn Air Dual Fuel beeping. The
Hello & Welcome to FixYa
Though this error is solved after replacing the touch pad assembly however, if you have already replaced it and the error returns then replacing the control board assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jul 31, 2011
Jenn-Air dual fuel double oven range - oven wont work.
You can make the repair yourself. What is the model number?
Nov 07, 2012 | Jenn-Air Kitchen Ranges
It is slow to heat up
The oven ignitor is slowly going out...it needs to be replaced!
Oct 25, 2009 | Jenn-Air JGR8855BDS Gas Kitchen Range
Oven not heating up
I would contact JENN AIR about their range . Many problems with things we have never seen . SORRY
Jan 01, 2018 | Jenn-Air Pro-Style® JDS9860BD Dual Fuel ...
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
