Question about Refrigerators
Amana fridge stopped working. Now working again.
Thanks for your input. There is not a problem with ice or anything like that, that I know of. Basically, the fridge was not cooling or freezing, but the light would still come on. I unplugged and replugged the fridge back in today and it started right up. I called the local appliance parts person, because I don't think that it magically started working again. The parts guy said that he was 99% sure it was the adaptive defrost timer. He asked if we had water pooling under the fridge. Well, we haven't had that recently although last summer there was this intermittent drip of water from the basement ceiling that is right below where the fridge is. He told me that the part is around $50 +/- USD. It is an amana side by side.SZD22NW P1162401WW SO# 9301163146. I found the part online and the guy told me it's looks like the motherboard on a computer and that when we look at it, we should be able to see that it might be black in some areas where the board has been fried. The thing I need to know is this. How do I get to that part from the back of the fridge. I know that I'm supposed to take off the panel, but there are several. I've tried to look it up on the web and can't find a blow up diagram that would show me where, on this model, that part would be so we could look at it.
Thanks in advance for your help.
  • 958 Answers
Ok..so that is the mother board. it is not a mechanical timer but the adaptive defrost is integrated to the controller of the whole fridge.
anyway, look at the lower back portion of the fridge, near the wall , at the compressor compartment is a housing of the mother board. you won't miss it since a lot of wires goes to that box. unplug the ref, remove the cover of the box, remove all the wires attached to the board, and replace it.
i hope i was able to help and please do not forget to rate on the original post.
tnx 4 using fixya,
drcool
Posted on Oct 31, 2008
  • francis rivero Nov 04, 2008
    hi groover,
    were you able to replace the board? is the ref now working?
    please keep me updated.
    tnx again 4 using fixya,
    drcool
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
Freezer Works, Fridge Doesn't
I would replace the evaporator fan if you say its not working, but works when you turn it for a while. The bearing in the motor is m9st likely gone. There inexpensive to repolace and Im sure if you allready have had the rear panel off you will have no proble replacing it. Good luck
Aug 14, 2007 | Amana AFD2535DES French Door Refrigerator
Build up of ice in back of freezer and now just won't not keeping anything cold
Freezer fan not working. Build up ice struck or hold the freezer fan. Defrost it manually and start fridge again. Thanks, helpful?
Jan 27, 2011 | Amana Refrigerators
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Jun 21, 2009 | Amana Refrigerators
Freazer works fridge warm
Hi Jen, I would suspect the thermostat. The fact that the fan is still coming on and off is because it is more than likely getting frozen or clogged with ice making it stop and in turn cooling stops. Yep I would start with changing the thermostat.
Mar 02, 2009 | Refrigerators
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
My amana sise by side fridge wont drop the ice
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Jul 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
