Question about iRiver H340 MP3 Player
Unit has locked up.
My unit upon startup will go through the boot process to include startup page and play page. As soon as the play page displays, the unit will then show that there is connected data with associated icon. I can not turn off the unit nor can I access the menu to start the application. None of the inputs respond and the unit will continue to be powered up until the battery runs down. I can access the unit through the USB connection but it will not play on its own. Any informaion would be helpful.
  • 1 more comment
  • andlypee Nov 21, 2007
    MY H340 starts up but then stays on the loading page and goes no further. Ive tried the reset button and connecting to a computer but it will not go any further that the loading page. I think it is a software problem but i can't get it to appear on my computer to try and wipe the unit and start again as it just always says loading.
  • geddy N Jan 24, 2009
    The car charger I use has a variable output and accidently got switched to 9v.. When I corrected this it switched to the Connected Data screen and I can't get it out. Whenever I power the unit up it gets to the normal music control screen and then switches to Data mode. The only buttons that seem to work are the control lock and the rest button which works but the unit then repeats it's boot problem. no problems wih actually connecting to the pc though.
  • Anonymous Mar 21, 2009
    My Iriver will go through the boot process then display the CONNECTED screen and will not let me do anything alse with the player.
The only way I got my H340 off the loading was to plug it into the computer through the data port, then unplug it then plugging it in to the media port then unplugging it. Then it would let me go to the menu. I tried to reformat it, nothing just wiped out all my music. I tried re installing firmware, nothing. I hope this helps.
Jill
Posted on Nov 30, 2007
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Word processing included?
Hello
Sometimes bundles, have 60 days free, office, or 90. as soon its complete trial days, expire. you have to buy the whole office.
you can find a few licences on microsoft page to buy it
Carl
Mar 24, 2014 | Gateway All In One Pc Unit With 20 Screen...
Compaq dx2000 mt freezes on startup
Boot into Safe Mode by pressing F8 during boot and...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 12, 2012 | HP Compaq dx2000 Microtower PC Desktop
My display window on my washer reads F and then dL.What does this mean?What do I do?
HI. That code is in reference to the door locking mechanism. It is experiencing difficulties at this time. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
The necessary actions are to Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU). This can be achieved by removing the top and front panel. The door assembly must be removed as well. Once you have exposed the door locking mechanism and its respective connections to the CCU, kindly, inspect each connections for a loose fit. The CCU will be located on the top of the unit, just to the rear or side of the interface panel. Check the linking connections that run to the door locking mechanism for a loose fit, as well. If all connections check out ok,simply, replace the door locking mechanism(switch assembly). This will correct the issue.
I have included a service manual for this unit. This duet service manual will guide you through the necessary disassembling process, as well as, the proper testing procedures for the door locking mechanism and CCU. The common fault here in your case will be a damaged door locking switch assembly, and replacing it will solve the problem. Click here to access your service manual.
Component accessing procedures will begin on page 4-1. The door switch assembly removal procedure will start on page 4-3. it is part of the door removal section. Follow it carefully to extract the assembly. Componet checks start on page 5-2. You can test the CCU door lock solenoids for proper ohms by referring to the ohm chart on page5-3. The CCU pin connector location is labeled on the top of page 5-1 under door lock solenoids. Due to the fact that there is a very small possibility that the CCU may be damaged, you can test the pins to verify that the CCU is indeed functioning with a good set of door lock/unlock solenoids. This will, essentially, isolate the door lock switch assembly as the lone culprit.
  • Be sure to unplug the unit before attempting this repair and use caution.
Aug 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dell inspirion 1525 will not boot upon power up...only displays locked 9 light solid
This is a Hard Drive error. If your unit is under one year old, you can get the drive replaced by Dell.
The drive can be accessed outside the laptop to retrieve the data, but it may fail all together very soon.
If you have no data on it, just get a new Hard drive installed. Dell should be able to replace the drive and start the system restore for you.
Mar 28, 2010 | Dell Computers & Internet
With the VHF on I can here the signal coming from the transponder, The orange indicator light soon changes to green pulsing gently. The E80 display unit displays ''No Data Source'' yet when the...
I would recommend upgrading the E80 and the DSM to the newest software levels:
E80 - 5.52
DSM - 4.12.
You can download the software off raymarine.com and load them onto different compact flash cards. Both softwares are upgraded through the E80 display.
Jan 29, 2010 | Raymarine St60 Plus Package, Includes...
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
Toshiba laptop will not startup
Without being about to do a HANDS on inspection of the laptop, it could have a couple of possible problems.
Here is my Best guess as to the probable cause. You have a loose/damaged connection on the Display screen. More than likely the power supply line to it. When it reboots it cools enough to pull away from its connection. Then gives you trouble rebooting until you apply and remove power several times. Why this is working by my theory is that each time you apply power it is sparking in that loose connection and slowly warming it back up until it finally connects again. Then all is fine until you reboot again and start the process all over.
This is a theory and I Can NOT guarantee that this is the problem. If it is. Then unless you are experienced at dealing with small electronics and high voltage. I would strongly recommend having it looked at by an experienced technician.
Sorry I couldn't be of more assistance
Dave
Nov 04, 2008 | Computers & Internet
LG RC797T Region Unlocking Codes
Purchased two of these VCR/DVD recorders (for the ATSC-digital tuner) in March 2007 at Best Buy. They play PAL/region 0 out of the box. To enable region-free playback I used the CD-ROM previously made for my LG LST-3510A. Visit this link for the files to burn your disc:
http://aiwaownersnetwork.tripod.com/pages/lg/5000_series_firmware.html
Next:
--Power on the player and load the CD-ROM
--In a few moments a text box appears displaying current DVD region and a second line to change DVD region
--Press the number you wish (most likely "0") on the remote control
--Press "Enter" on the remote control
--In a few seconds the player will eject the disc. Remove the CD-ROM from the tray and power off
Upon powering on the player my region 2 and 4 DVD's play fine but Macrovision still remains.
OR
Click the HOME button on the remote with the unit in 480i resolution
Click the setup page
Click Start
Click TV Aspect
highlight the 16x9 wide aspect ratio
enter on remote control this coded sequence:
1397139
Edit specific "Options"
Option 2: 35 (enables Divx/Xvid playback)
Option 4: ff (enables Vcd and SVCD playback)
Option 5: ff (enables region free playback (region 0) DVD playback)
Option 6: ce (enables Insignia brand startup logo on boot)
Option 6: c0 (enables LG brand startup logo on boot)
Sep 19, 2008 | Denon DVD-3910 DVD Player
Input Signal Out Of Range
press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Apr 11, 2008 | Akai LCT2060 Television
iRiver H340 MP3 Player Logo
101 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
