Display goes out
My monitor comes on for a few second and then goes out, Turn monitor off and back on same problem (what is the problem).
  • Anonymous Apr 02, 2009
    i have the same problem it takes about 10 minutes of turning on and off before it eventually stays on.
    Habit-Forming:
  • 3 Answers
I had a problem with my 1916w monitor where it came on and the monitor began to squeal, the screen went black and the noise stopped. The monitor power indicator whent from green to orange. It turned out to be two bad (domed) CapXon 1000 microfard 25v dc capacitors on the power board. This brand of capacitor has been a known cause of problems in various makers monitors. Replace these two capacitors and any others that have domed tops with a good brand of capacitor of the same rating. Replacing these two capacitors fixed my problem. I have disassembly instuctions for this monitor in answer to another persons problem in FixYa where he inquired how to get the covers off the monitor. Good luck and have a merry Christmas.
Posted on Dec 25, 2008
    Problem Solver:
  • 5 Answers
The problem is one or more failed electrolytic capacitors on the secondary side of the power supply circuit board.
You can often identify which one(s) (is/are) bad, because their tops often look "bulged", but replacing them all usually isn't a bad idea either.
Posted on Oct 31, 2008
4 Suggested Answers
SOURCE: monitor goes black after a few seconds
I have the same problem on my Acer AL1711. The monitor was out of warranty so I opened it up and found one of the 1000 mf capacitor almost ready to pop. A 50 cents replacement from allelectronics.com fixed the problem.
Not recommended for anyone without experience soldering electronic components to PCB's.
Posted on Dec 29, 2008
  • 38 Answers
SOURCE: HP 1940 goes blank After 3 Seconds. after turning on
Run a monitor aelf test.... Remove the monitor cable from the back of the tower... and see if it run self test.... also a install the driver for the monitor
Posted on Aug 03, 2009
SOURCE: I have a Dell monitor model #1901FP when my
The solution I am about to describe refers to a backlight problem, which is most common in Dell 15,17 & 19" monitors. The symptoms are as you describe:
  • You power on the monitor, the green on/off switch illuminates and the display works for approx 1-2 seconds and then goes blank.
  • The green on/off switch stays illuminated but the screen remains blank
  • If you shine a torch into the LCD matrix you can see the display being rendered faintly
  • Switching the monitor off and then on again illuminates the display again for 1-2 seconds before going blank again
This is a backlight fault and is most likely to be caused by the failure of two of the four driver transistors used to light the lighting tubes in the LCD Matrix. This fault is easy to repair if you (or a friend) have a soldering iron and a voltmeter.
Inside the monitor there is an inverter board that acts as a power supply for the monitor and the logic necessary to control the backlights (illumination and brightness control). There are four lighting tubes, which are controlled by two lighting circuits (two lighting tubes per circuit). At the heart of the inverter board is a chip that monitors feedback from the two lighting circuits and closes the back-light circuit down if either of the lighting circuits fail, thus any component failure will exhibit the same symptoms.
The transistors which fail most often cost pence to replace (types C5706 or C5707). However, their failure in unlikely to be the cause of the problem. My first crack at fixing this fault, by replacing the transistors, resulted in them failing again within 24/48Hrs. The cause of the problem will be dry solder joints or loose connections on the high-voltage side of the circuit, usually on the backlight transformer in the effected circuit. If you re solder each of the connectors on the transformer you will save the transistors from blowing again - the transformer generates 1,400Volts for the lighting tubes and at this voltage, arcing across the a dry solder joint, will quickly destroy the transistors again.
No soldering iron? - A complete inverter board replacement is also reasonably cheap and easy repair. These are widely available.
Sorry of this is more detail than you expected but it may help others reading this article.
Posted on Nov 28, 2010
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
HP 1940 goes blank After 3 Seconds. after turning on this monitor it goes blank if i turn it off then on again it will display the comptuer output again but then turn off after a few seconds. any hints?...
Aug 03, 2009 | Computers & Internet
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Optiquest q9 turns off
read the solution I have wrote on th Q7
display goes blank after few second
the fix is about 5 $ the supply is almost dead
Jan 18, 2009 | ViewSonic OptiQuest Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
535 people viewed this question
David Payne
David Payne
