Question about Hotpoint Washing Machines
Hotpoint Washer turns on water comes and drains but seems Motor not working as opened top and checked.
  • 209 Answers
SOURCE: hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Posted on Sep 09, 2007
  • 106 Answers
SOURCE: Hotpoint washer won't drain water out
lok from the botom of the machine you will se a filter ,open it ,clean it a put him back in the place
Posted on Feb 05, 2008
aborcass
  • 2651 Answers
SOURCE: How to open washer to check and fix lid switch
the lid switch can be changed without removing from closet for sure,you can remove the angular access panel between the2 units youll see 2 brass clips holding the cabinet to the top, slide the entire top toward you to remove. its located under there. there may be 2 screws across the rear of main top holding down as well but yea pulling out will get you kn more access to any component
Posted on Mar 16, 2008
shaggyrat
  • 1224 Answers
SOURCE: Hotpoint WD440 1400 Spin
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
Posted on May 21, 2008
  • 4 Answers
SOURCE: maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Posted on Jan 16, 2009
Washer machine hotpoint aquarious the five side lights flash and the top spin light flash all the time and machine wont work
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution as you think fit. Thank you and good luck!
John C
Apr 10, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF210 FRont Loader Washer The machine will not empty and not able to open the door.
Here are my comprehensive guidance notes for checking both the drain motor filter and the drain motor ;-0)
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 29, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Door for Hotpoint WD440 not opening, latch is stuck. Have opened machine from the top and can not find a way to release the latch.
Is it 'stuck' or is the washer keeping it locked are the questions!
It is worth trying the following JUST in case.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
John C
Mar 25, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint WMD 960 WASHING MACHINE and it smells
Probably stale water or smelly lint/fluff.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
John C
Mar 22, 2011 | Hotpoint Washing Machines
HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
Broken washer
could be clogged drain. look at my issue "eco smart won't drain, smells hot" on how to remove motor from bottom of washer and check lower drainage area. bail water out first and be ready to catch water when you remove that motor unit.
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Hotpoint WD61 stops near start of wash cycle
all in the timer. but there may be nothing wrong. sometimes in the cycle there will be a gap between water full and agitate or between drain and spin depending on settings. try it again and let it go and if there is a gap of more than 5 minutes than it needs a timer. most machines timers are right around $75 and you can most likely replace it yourself. sears appliance parts is the place to buy it. you can order it and they will deliver it to your door. or if you can get the phone # most of the outlets have a parts dept. also they take parts back for full credit for any reason.
Mar 05, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint washer , top load
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Jan 01, 2008 | Hotpoint VBXR1090D Top Load Washer
HOtpoint washer
check these
1)the drain hose is kinked
2)Does the lid switch click when closing?
3)Something in the pump or hoses? Check the hose coming down from the tub for socks, rags, etc.
4)Bad wigwag
5)Broken belt? Loose belt?
Also the pump would be the first culprit to check. I believe that the pump in this model is electric and not driven by a pulley, so switching out should be easy. First you want to verify that you have power going to the pump while in the drain cycle. If you have power going to it and it's not pumping water out you can be pretty sure that is the problem. The front panel can be removed by removing the two screws at the bottom and lifting out. Now you can get a good look at the motor and pump.
Oct 21, 2007 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
