Question about Canon EOS 400D / Rebel XTi Digital Camera
EOS 400D "lag"
Using the camera on sports mode, but its started slowing between shutter operations - I was using this quite successfully to shoot fast jets. Now this isnt possible! I dont have the option to reset the camera to the defaults(?). This first seemed to happen when I tried to use the bg-e4 battery grip, but removing the grip and going back to my original battery, the problem still persists. Any advice???
Ross
  • rossm55 Dec 06, 2008
    Brilliant - well done Barry!!!
  • adrian5beech May 11, 2010
    Have you changed cards - some write faster than others, and consider that the light in the winter is much less than summer - it could just be that the shutter speed is longer, so less time available to prepare for next shot. I guess if you did a sample series set at 100 iso, then 1600iso, you would find a noticeable difference. It could be as simple as that - you just need more light - or you could try a lens with a bigger maximum aperture. I use a 400mm equivalent lens, and it is about f3.5 maximum. In this dull light, my shutter speed is about 1/250 second, but it is image stabilised, so no problem on stationery subjects. However, a fast jet is another thing altogether - You may just have to buy a faster lens with the bigger aperture, or even try the Nikon cameras with the low noise at 6400 iso, or even higher iso. Of course - it could be the camera, but I think you should try the alternatives first
    Regards
    Adrian
  • 23 Answers
Try reformatting the card. I don't know if this camera allows you to do a low level format or not. If you can do that.
Posted on Dec 05, 2008
How to set Shuttler Speed
As with most point&shoot cameras, the M753 doesn't give you much direct control over the camera. It expects you to just point the camera and shoot. You can "suggest" to the camera that it use a fast shutter speed by setting it to the Sports scene mode, or that it use a slow shutter speed by setting it the Landscape scene mode (though the latter would also set the focus to infinity).
Jan 18, 2013 | Kodak Easyshare M753 Digital Camera
How do I change the shutter speed?
You can't change the shutter speed on a point-and-shoot camera. You can change modes and some settings that will force the camera to fire the shutter at faster speeds. For example, if your camera has a "sports" mode, that will fire faster. You can set the ISO to a higher setting to cause the shutter to fire faster.
May 14, 2010 | Nikon Coolpix S1 Digital Camera
Shoot at speed
The sports mode on a DSLR just picks high ISO and fast shutter speeds for you. Go Karts are very fast subject to focus on, so there are two techniques you can try.
One is to set your focus to manual mode and pre focus a point where the car will pass through. Set the camera to multi shot mode and just before the kart gets to the pre-determined point, hit the shutter button. The camera will fire off a few shots, then review later on a computer to chooset the best one out of the sequence.
Another way is set your focus mode for AI-Servo or Focus Tracking mode, this will enable the lens to track moving subjects (as single shot mode is way to slow to keep up with karts). Go to the slowest part of the track to get more sucess.
One problem you maybe having is that the shutter speed is too slow for karts. Being indoors the lighting will be very poor, so a super high ISO rating will need to be used to get faster shutter speeds. Having a lens with a very wide aperture (like f2 of f2.8 or even less) will enable you to get faster shutter speeds because they let in more light.
Good luck.
Jan 17, 2010 | Pentax K110D Digital Camera
Shutter speed actomatic change
If you move from mode to mode, the camera will remember the settings from the last time you were in that mode and reset to them. This is handy if you are in shutter priority shooting sports at a high shutter speed, and then want to take a picture of something that's not moving fast, like the crowd. You just pop it into aperature priority with a remembered settings of a higher f stop.
I use this to shoot the scoreboard, which has a fairly slow refresh rate and usually comes up blank if I shoot it at a shutter speed higher than about 1/100.
Sep 02, 2009 | Nikon D300 Body Only Digital Camera
My EOS 300d blank images
That problem is normally associated with having a too high shutter speed when using flash. If it happens in any mode, with or without flash you may have a shutter blind issue.
Test the camera at various shutter speeds and compare the results. If this black area is consistant across different shutter speeds, send it in for repair. It is most likely the shutter curtain not making a pass across the sensor fast enough, still obscuring the sensor when a photo was taken.
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xsi, using 75-300 lens, taking photos of basketball game, pictures are blurry, especially the ones in "action" using the sports mode. also tried my 18-55 IS lens, same thing happening, using...
That's a big lens and for sports photography you are going to need a lot of light to ensure you can use a fast shutter speed to capture the action. Sports mode may do too much for you and you might want to try switching to a more manual mode. Try switching to Tv mode which gives shutter speed priority. Set the shutter speed to something around 1/150 or higher (1/200) which should be fast enough to freeze the action. Make sure the ISO is set to 200 or 400 for best results and see how you get on. This should stop any action based blur which would leave you with focus problems if the pictures are still blurry. Check out http://www.dpreview.com/reviews/canoneos450d for info on what this camera can really do for you
Jul 28, 2009 | Canon EOS Rebel XSi Digital Camera
EOS 30D is slow to fire.
Are you sure you aren't in the delay setting in drive mode? This camera has 2 delay settings, one for 2 seconds between when you press the shutter and when it takes the photo, and one with 10 seconds delay - often used when you want to be in the photo (e.g. self-portrait or group photo).
If you aren't in the delay mode, then I need to know more about your settings. What shooting mode are you using? What type of photo are you trying to take (portrait, landscape, sports)? Are you shooting indoors, outdoors, bright sunlight, overcast, etc.?
Dec 30, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
400D manual mode
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
Dec 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Continuous Shooting
must be something to do with the mode you are using like auto mode, manual mode P mode so on...havn't use anything else the the manual mode so do a hit and trial procedure. Also be sure to increase the shutter speed...
Jan 13, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
70 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
