Question about Zenith XBS344 System
Dvd door The DVD/CD door will not open. It doesn't open when I push the button on the system or when I use the remote. Is there a way I can get it open without breaking it? Is this fixable? Thank you, Denise
  • m87sam Dec 23, 2007
    The DVD door will not open regardless if I use the remote or the button on the unit.....please help.
The door is probably not opening due to the gear pulley either came loose that drives the door open closed or the little belt that goes on the pulley to the motor is broken. The (belt) can be replaced with a small 1& 1/16th X 1/16th oring.
Posted on May 15, 2008
I had the same problem. It started after I plugged a PS2 into the system using the A/V cable ports in the front. I discovered just by unplugging the cables the door opened again.
Posted on Jan 12, 2007
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: dvd door
In the user or instruction guide, there should be a way they show you how to open the tray door if a disc becomes stuck most of the time. if it does not then the unnits going to have to be taken apart, and if you havent a clue how it disassembles you could cause more problems. The units going to have to go into a repair shop because this is a solid state unit and its not a serviceable unit to a user.
Posted on Sep 13, 2006
I CAN NOT OPEN MY DELL INSPIRON 15 CD TRAY
Almost all cd and dvd or bluray drives have a manual way of opening. Usually it is a small opening to the right of the button to open the drive. Make sure the system is OFF to try this. Just straighten a paper clip and insert it in the opening and give it a small push. The door should manually slide open.
Jan 30, 2014 | Dell (0F146) Internal DVD Drive
Tip
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
on Aug 02, 2010 | Samsung DVD-P241 DVD Player
Tip
How to use a paper clip to open CD or DVD door
I have answered many questions about CD and DVD drives. One of the most common problems is "My CD door doesn't open"
This can be caused by several things but I am going to explain how to open the door manually.
To do this requires a small Paperclip. Straighten the paperclip. Find the small hole in the CD or DVD door. Gemtly insert the paperclip and push on the button inside. If the drive does not have a mechanical problem the door will open.
on Apr 05, 2010 | Computers & Internet
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Installed a new dvd burner for Hp computer. Running Windows XP. Installed Nero 8 Software. Door doesn't always open when button is pushed or after burning a dvd. Computer also has another cd/dvd drive....
it has to do with a new hardware installation process....check IDE cable that they are correctly connected and try to check system setup so that the CMOS identifies both, primary & secondary devices....if not, u need to install a driver for the newly installed one....
Oct 05, 2009 | Computers & Internet
CD/DVD door will not open
I have the same problem once in a while usually after a disk read error. If you power off the system (unplug it) it will reset and the door will open.
Jul 13, 2009 | Bose Lifestyle 18 System
Dvd door
Sep 13, 2006 | Zenith DVT216 System
Zenith XBS344 System Logo
219 people viewed this question
Top Zenith Audio Players & Recorders Experts
Marvin
Marvin
xalint1
xalint1
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
