Question about Philips 60P8342 60" Rear Projection Television
Philips 60P8342 picture blurry with orange tint
Hello All,
I have a Philips 60 inch 60P8342 rear projection tv. The picture is going a little blurry as well as the whole picture has an orange tint through it. I have no idea if the tv has bulbs that needs to be replaced or what. Any help in solving this problem is greatley appreciated.
  • 1 more comment
  • sbennett1182 Nov 28, 2008
    THERE IS BLURRYNESS AROUND THE EDGES OG THE TV
  • lb75 Dec 14, 2008
    I have the philips 60P8342. The picture is blurry with green tint and blurry around the edges.
  • Anonymous Jan 30, 2009
    my television have a orange tint
    New Friend:
My hitachi tv 65g500 is showing like the bulb is about to go out you can still see the tv but the writing is blurrl please help
Posted on Aug 12, 2013
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your philips 60P8342 picture blurry with orange tint - 2c07611.png chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen tphilips 60P8342 picture blurry with orange tint - 578ba6c.jpg, red/orange, etc. You may even see halos around images.
Pictphilips 60P8342 picture blurry with orange tint - 65af323.jpgt that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 22, 2009
You probably need to change crt coolant
Posted on Mar 14, 2009
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
60 inch has no red
Hi, you`ll need a tv tech for that one, either no red out from rgb chip, bad driver ic, etc. none of these repairs can be done without special tools, video-tek
Jun 29, 2009 | Philips 60P8342 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Picture is to light
Hello nita-1991,
Go to the Philips site http://www.philips.com and get the users manual. them get the remote for your TV from:
http://www.magnavoxremotes.com/
I hope this helps
Shuttle83
Jul 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 60P8342 60 in. Rear projection tv
Thats the High Voltage generator. We have a new one on our site for 53.99 and offer overnite shipping for an addittional 25.00 we also include step by step instructions on how to replace the component. Here is a link to our store. I moved it to the front page so you can see the picture of it. thats the part youre needing.
http://servicemanuals.vstore.ca/
Mar 10, 2008 | Philips 60P8342 60" Rear Projection...
No Picture
you have sound, but there is no sound?? or do you mean picture?? try replacing the bulb!!
Dec 24, 2007 | Philips 60P8342 60" Rear Projection...
No remote Philips 60P8342
I checked with my parts distributor = remote sensor no longer available.....Philips part # 932215244687...........................T.
Dec 19, 2007 | Philips 60P8342 60" Rear Projection...
Television Turns on and then Turns Right back off!!!
Either a short in the High Voltage section or power supply section. If you are not a TV technician you will have to find a reputable repair shop to help. Good luck.
Aug 01, 2006 | Philips Magnavox 9P6034C 60" Rear...
Philips 60P8342 60" Rear Projection Television Logo
409 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
