Question about Belkin (F5D7230-4) Router (587009)
Wireless can not communicate with my comp
I have full bars but no internet connection
    Genius:
  • 1,605 Answers
Do you have encryption set on the wirless???
if so, you need to enter the encryption.
of not, uninstall the wireless from your computer and reinstall it. reconfigure the wireless setting.
Posted on Oct 30, 2008
2 Suggested Answers
Luddite666
  • 10 Answers
SOURCE: wireless can not communicate with my comp
I'm assuming you are using windows XP or similar. You can check your tcp/ip protocols and local pc adaptor by 'pinging'. open the command prompt - 'start', 'all programs', 'accessories', 'command prompt'. Then type 'ping 127.0.0.1' without quotes. If there is 'no loss' of data, your pc is basically sound, as are the protocols.
Try reaching your router by typing 192.168.2.1 (or look on bottom of router or documentation for IP address). It may ask for user name and password which should be with documentation. You need to be able to reach your router before you can use the net.
If using a cable, check out your LAN by going to 'control panel', 'network connections', then find the LAN icon. Right click and left click on 'properties'. under the 'general' tab scroll to ' internet protocol tcp/ip'. double click on this. under the general tab make sure ip address and dns is obtained automatically.
If you're using the wireless capability (ie not network cable) right click on the wireless connection to 'view available networks'. try to connect to one. You may need a WEP/WPA etc password. You could try connecting a network cable from pc to router to see if it's a wireless problem or not.
In control panel look at 'internet options' and 'connections' tab. make sure it's set to use the right connection (eg mine just uses the LAN).
sorry if this is a bit muddled but there are many possibilities. Any more info on your setup would be helpful.
Posted on Dec 04, 2008
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
The red light is flashing and when i try to get on with wireless it shows full servise but will not pick it up
which light is flashing red, wireless, ethernet,or internet? Check settings on computer. It does not sound like a modem problem. If you have another computer, see if it connects or if it has same problem. Configure wireless settings on comp.
Feb 03, 2011 | 2wire (1000-000057-000) Modem
I m using a toshiba L310 laptop & it was fine with a wireless internet connection but suddenly it lost connection & its not connecting anymore. what can I do now?
restart your comp and your router, if that doesnt help try and update your drivers to your wireless card in your comp., if everything is updated and the wireless in you comp is searching then it might be the router, they commonly overheat for heavy use
Sep 18, 2010 | Internet Computers & Internet
No wireless light, and no wireless signal detected
there is a possibilty that wirelss feature on ur router is not turned on as the wireless light is off.
U can open the gui(router page) of ur router by entering the default gateway on the browser address bar. First of all u would need to connect ur comp using the cable to ur router so that it could be connected to internet.
Go to command prompt and type ipconfig and press enter and it will give u the ip and default gateway of ur router.
U can type the same default gateway in the address bar of internet exploere and hit enter and it shud bring the router page.
Once u r on the router page u can check the wireless settings on to that and can alter them.
Jun 07, 2010 | Belkin Wireless-N Wireless Router with...
Airport says full connection to wireless router, not online tho
if it says you have a good connection, it means that you are connected to the router, though the router might not be connected to the internet. try powering off/on the router (leave off for 10sec.) to see if that corrects the internet connection issue.
Also, when it says that the connection is good, open a web browser and type 192.168.1.1 or 192.168.0.1 or 10.10.0.0 into the address bar (you can find this address by going to Network properties and looking at the Wireless settings. It should say "gateway" or "router". If you put that address in the browser it will pop up with the Netgear settings page if you have a good connection to the router. If so, then it's a problem with your router connecting to the internet and you might have to call your ISP/cable/phone company to get it fixed.
Apr 15, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computer say my wireless mini card not connect i
type this in your internet adresse bar 192.168.1.1
that will take u into your router
good luck
Mar 16, 2009 | Computers & Internet
Dec 04, 2008 | Belkin (F5D7230-4) Router (587009)
Connection problem
you need to type 192.168.0.1 into address bar on internet explorer if this does not bring up a password prompt then you need to set your ip addresses on both computers this is done by clicking start - my network places - on left view network connections - right click on wireless for wireless and on normal lan for lan - click properties scroll down to tcp ip sttings - right click - click properties - click use the following ip address - type 192.168.0.2  - click sub mask it will auto fill then default gateway needs to be 192.168.0.1  - then click use the following dns server and type 192.168.0.1 click ok and your done for every computer you add to the network you have to change the last digit of the ip address such as 2 then 3 then 4. go back to internet explorer type 192.168.0.1 you will get the password prompt the user-name is admin and password is password
once done you need to check it is connected to the net it should say on the first page. if you need anymore info msm me moc.liamtohat1202gniksirhc
Oct 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Belkin (F5D7230-4) Router (587009) Logo
74 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
