MY FRONT LOADING MACHINE IS FLASHING THAT DARN F6 AGAIN
IT HAS HAPPENED BEFORE, AND JUST SEEMS TO HAPPENING MORE OFTEN AGAIN... WHAT IS GOING ON WHAT CAN I DO TO FIX IT AND MAKE IT WORK RIGHT!!!!MY FRONT LOADING MACHINE IS FLASHING THAT DARN F6 AGAIN
AnonymousMay 03, 2009
I push the control botton and I hear a click, then I push the start botton and I get another click and then the codes "F" and "6L" start to flashI push the control botton and I hear a click, then I push the start botton and I get another click and then the codes "F" and "6L" start to flash
You can't post conmments that contain an email address.
unplug the washer, remove the lower front panel, put your hand under the front panel and pull a little lever behind the door lock mechanism and pull the door open.
There may be blockage/clothes in the pump. Try taking off the bottom cover so you can get to the pump. Disconnect hose to the pump and check to see if anything is in there. If not let us know... thanks
If these procedures do not correct the error, you may have a more serious problem. If you need further assistance, please let me know. I hope this helps you.
This is joyce
I just had to have my barrons replaced in my washer on the spin cycle it sounded like plane taking off. I dont know about yours but mine was loud, you probl. have the same problem. get a technician to come and check it out, all these machine's are hard to work on so let professional take care of it. if you need me to find someone in your area please just let me know.
thanks,
joyce
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
