Question about Ace Hardware Hunter& Low Profile III Ceiling Fan
Hunter sprinklers vs rainbow sprinklers
Any advice in wich system is more relible a peter protuct
  • 33 Answers
I work with both Hunter and Rainbird irrigation components. Both companies have good products. But, I prefer Hunter for the sprinkler heads and Rainbird for the controllers and valves.
Posted on May 16, 2010
I need to turn off one sprinkler head of my Hunter Pro C unit.
you can turnoff the solomoid which opens and lets water thru. Sprinkler heads are not wired, they open with water pressure
Nov 18, 2017 | Hunter Garden
How do I get my Hunter ICC irrigation control box to turn on?
Check batteries with tester. Check internal fuse (sometimes same compartment as batteries. May have have to spend the $20.00
Jan 18, 2015 | Hunter ICM-400 ICC 4 Station Sprinkler...
Manual for hunter sprinkler system model number 700765LIT335
Did you try the manufacturer's website?
Jul 07, 2014 | Garden
Hunter pro C will not allow all zones to water.
The fact that you are getting no error message indicates that programming is not right, or there is electrical short between timer and sprinkler solenoid:
With all digital timers, it is important to clear memory before starting, and then double-check there are no conflicts in programming.
Page 22-23 of the manual has quick-check procedure for identifying shorts that would cause problems.
Check outlet with circuit analyzer to check for correct polarity and grounding.
Google search Hunter Pro C manual to download searchable pdf manual
Keep in mind also that digital timers are susceptible to line noise, and power surge. Simple power outage can disable digital timer. There are no replacement parts.
That's why I recommend good old fashion 14-day repeat-cycle mechanical sprinkler timer with fewer features, but replaceable parts.
For example T8845PV with 24Volt ac output
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html#T8845PV
Jul 15, 2012 | Hardware & Accessories
My hunter SRC lawn sprinkler controller sprinkles t
First thing to check is the power supply. Are the batteries fresh? Most likely you need to reprogram. There is likely a previous program that is causing the errant watering. Here is a good video on how to program.
Oct 22, 2011 | Nelson Sprinkler: Traveling Tractor
My Hunter PGM sprinkler heads are stuck in the same position. Any way to fix this?
Hunter has released the PGJ sprinkler, a direct replacement of the PGM series. With a rubber cover and the smaller PGP type gear drive, the PGJ series rotor should solve your issue. I would look at www.hunterindustries.com and find a wholesaler near you for costs of replacing your PGM sprinklers.
Jul 18, 2009 | Ace Hardware Hunter& Low Profile III...
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Hunter PGP Sprinkler Problem
For a small price, it's worth it to replace it with another Hunter PGP. Don't settle for cheaper products as the PGP is the best in the industry, bar none.
Jul 09, 2008 | Ace Hardware Hunter& Low Profile III...
Ace Hardware Hunter& Low Profile III Ceiling Fan Logo
329 people viewed this question
Top Ace Hardware Dryers Experts
Are you an Ace Hardware Dryer Expert? Answer questions, earn points and help others
