Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Clothes covered in lint
My whirlpool ultimate care II washing machine will not go thru the cycles, but i manually make it change. also, alot of my clothes are covered in lint upon removal from the washer. any suggestions
  • mebiddle Nov 03, 2008
    tech repair person confirmed that this was the problem thanks
    Novelist:
    Champion:
  • 261 Answers
You need a new timer. Reducing the cycle time will help the lint and not having a timer stuck on wash will help too.
Posted on Nov 01, 2008
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
All my shirts are ending up with fuzz balls . Is there a lint filter?? i can't seem to find it .
There is no lint filter. Make sure you have enough water to float the clothes. Try washing your shirts with the permanent press or gentle cycle.
Nov 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Grey lint all over sheets and dark color clothes
less soap and shorter wash time or wash on perm press cycle but this is a common problem.
Jan 23, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Mar 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
277 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
