Question about Samsung TXJ2767 27" TV
Diagnosed, fried resistor.
Found a fried resistor, and I am going to replace it. Anything I should be looking out for when replacing it? IE: Anything holding a charge. I am good with a soldering iron, going to solder this beast in, got a matched resistor to replace it. I am no technition but some info would be great thanks.. no lectures please.
    President:
  • 3,130 Answers
Where is the resistor located and whats it feeding? A resistor will not fry all by itself. Its like a fuse, its there to cook so nothing else does. Sorry to say your taking a big chance by installing a resistor without checking what circuit it is in and whats it feeding. It could possibly cause more damage to the power supply or the sweep supply. Good Luck
Posted on Sep 13, 2006
Blower not turning to push air and heat through vents, Replaced blower motor, still not working. How do you get to the dash wiring to check electrical connections. fuse is good.
Replace the Blower Resistor. (About $12).
The resistor might be good; I have found that the terminals corrode, create resistance and sometimes melt the connector (About $100). Check the resistor before replacing it! If the connector gets fried, solder pigtails onto the good resistor and use Marr connectors to attach the pigtails to the existing wires,
Jul 12, 2010 | 2001 Dodge Dakota
Blower motor resistor overheats and fried connector to blower motor on 2001 Grand Caravan. Replaced resistor once new one fried connection. Saw review online that the resistor diode may be the culprit....
You should be replacing the blower motor with the resistors. If your buying the parts from the dealer an experienced parts person will insist you replace both at the same time. The blower motor is usually what burns out the resistors.
Jun 05, 2010 | 2001 Dodge Grand Caravan
Picture comes and goes by itself. I get sound but no picture
hi...your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 large IC's , probably STK392-040, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps u alot...
thank u!!!
May 24, 2009 | LG 32LG30 32 in. LCD HDTV
Fan blower doesn't work
I have the same truck. Mine only worked on high. I replaced the blower motor resistor and it worked for a few seconds and then the resistor started to overheat and fry. I then removed the blower motor and found it to be pretty seized up so I replaced it along with another resistor and it works great. At any rate, be careful not to ruin a new resistor. If it shows any signs of getting hot when you first fire it up then turn off the blower motor immediately and replace it too. In my case, the worn out blower motor is probably what caused the original resistor and the replacement to fail in the first place.
Apr 22, 2009 | 1988 Mazda B2200
Having trouble with red convergence
Your TV has gone crazy on you because your convergence IC's have gone bad.   These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.   Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go. If you need to order a resistor or two,
http://servicemanuals.vstore.ca/index.php/cName/convergence-resistors   If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!   If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at manualuniverse.com
Hope that helps!
Jan 21, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Convergence is is off
Hope that helps!
Jan 21, 2009 | Panasonic PT-51SX30 51" Rear Projection...
Need help adjusting the rear projection red light in my tv
Your red has gone crazy on you because your convergence IC's have gone bad.   These IC's operate at a very high temp, and usually only last 4-5 years.
You will also need some "Heat transfer paste" - you can pick this up at radio shack.   Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.   If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!   If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at servicemanuals.net   Hope that helps!
Jan 04, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Samsung TXJ2767 27" TV Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
