Question about D-Link AirPlus DI-524 Wireless Router
Connection We have had this router for a couple years and it worked fine before. We had our computer worked on and everything was erased. Unfortunatly we no longer have the box or passwords or anything. All we have is the router and the part that attaches to the upstairs computer. When I try to run the enet cord through the cable modem I am unable to connect to the internet. I am trying to have the router hooked up so I can use the installation wizard to reconfigure the router. I can't connect though. Can anyone help?
    Genius:
  • 1,139 Answers
Hello ryanhendrick,
You are going to have to reset the router to its default values. To do this fine the reset button and push it in holding it for 15-30 seconds until the router reboots (all LEDs flash). Now once this happens you will be able to use the default login of admin and the default password of (this is left blank) to loginto the router. You will have to reset all of your old values.
I hope this helps
Thank you,
Shuttle83
Posted on Oct 30, 2008
    Genius:
  • 1,124 Answers
Router worked fine for a couple of years. Today, an update to Internet Explorer was installing and the baby unplugged the computer. Now the internet works when the cable modem is connected directly to...
Keep the baby away from your equipment ... it is dangerous for the baby to be pulling on wires ...
Turn everything off ... everything ... unplug your router ... at the rear, find the small hole ... insert a paperclip into the hole ... depress and hold the small button inside for 30 or more seconds. Plug in the modem ... wait for it to settle down. Plug in the router power ... press the button again with the power on. Connect the uplink (wire from the router to the modem) ... let things settle down again ... plug in other network wires ... wait ... turn on your computer(s) you will now have a router that is back in new condition with factory settings ... if not ... replace the router, there is a fault in the device.
Thanks for using FixYa.com
Oct 04, 2010 | Linksys Wireless-G WRT54GS Router...
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Dec 29, 2009 | Adtran NetVanta 3200 Router
My d-link wireless router lights turn on properly but it is not sending any signal and when connected by lan the computer says limited connectivity
Try resetting your broadband connection, then the router, then your computer in that order.
These devices get out of sync on their addressing occasionally and a front to back reboot is all they need.
Dec 09, 2009 | D-Link DIR-615 Wireless Router
No longer able to connect laptop to the internet with wireless modem. Have had to disconnect and work only from desktop. Have used this for a couple of years and suddenly stopped working. I can see the...
What did you install last on the laptop?, if its anti virus disable it and try connecting.If after that it does not work ,reinstall the computer OS something is corrupted.It's definately not the router issue.
Dec 08, 2009 | Computers & Internet
I have a Linksys wired router, which I have had for years and everything worked fine until a couple of days ago when I was no longer able to connect to the internet. I disconnected the router and connected...
Do this with your network setup. Power down your DSL/Cable modem first by unplugging the power. Power down the router next by unplugging the power. Power off your computer also. Now , power up the dsl/cable modem and let it resync with the ISP ...all lights green and showing activity. Next power up the Linksys router and then do a factor restore reset by pushing in the reset and holding it for a count of 5 (the front lights will go red then flash) let go of the reset as your linksys router is all set to default setttings from the factory. Now power up your computer and try the internet after it boots up. Should hook to the internet with no problems now. Now access your router menu by typing http://192.168.1.1 and hit enter. The router log in menu should now display. just click on the password tab and enter admin the default password and then change your password in the router to something hard to remember and WRITE IT DOWN! There is also great help from linksys web site on networking your home. Good luck,
Nov 10, 2009 | Computers & Internet
Belkin Wireless Router will not go wireless.
go to your configuration site and make sure you have the SSID broadcast option on
Jun 22, 2009 | Belkin (F5D8231-4) Wireless Router...
1 of the 2 computers cant get online
Pleaase check if the PC connects when plugged directly to the DSL or cable connection whatever you have without the router in between. That would ensure the functionality of the ethernet card on the other pc.
Feb 10, 2009 | NetGear MR814 Wireless Router
Network has suddenly dissapeered
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Can't connect to the internet
PirateX,
I would first recommend unplugging the power to your modem, router and turn off your computer for a couple minutes. Then, one at a time, plug everything back in...modem first, router, then computer back on.
If this does not work, please let me know.
moriarti5
DigitalBrainz, Inc.
May 23, 2008 | Linksys Wireless-G Broadband Router
D-Link AirPlus DI-524 Wireless Router Logo
23 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
