Question about Dayton 511 Utility Heater
Dayton Furnace Wiring Diagram
I have an older hanging heater and the wiring diagram is gone. It is a Dayton brand heater. The BTU is 125000. I sure need the wiring diagram.
  • 15 Answers
SOURCE: Venting a Dayton 4E454 24,000 BTU gas furnace
If you intend to use this in a residential garage, you will have to use standard galvanized round pipe coming off the unit, 24 gauge will suffice, use a minimum of 6”-8” from the unit. From there you will have to make the transition to the B-Vent. Always double check with you local codes in your area.
Hope this helps.
Posted on Dec 02, 2008
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Posted on Dec 07, 2008
  • 3182 Answers
SOURCE: I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Posted on Dec 08, 2008
  • 3 Answers
SOURCE: wireing
Go to your local Grainger and they will print it out for you.
Posted on Jan 13, 2009
  • 12744 Answers
SOURCE: no ignition on dayton gas furnace. how hard is it
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Posted on Oct 31, 2009
I need a wiring diagram for a Dayton model 3E402D gas heater
Contact Dayton directly and request a wiring diagram for a Dayton model 3E402D gas heater.
Jan 14, 2018 | Dayton Heating & Cooling
I have a 75k BTU Dayton hanging gas heater that the fan comes on intermittently. The flame will shut down and try again, then the fan will come on.
This problem is caused by a bad flame sensor (looks like a spark plug) which can be cleaned by sanding or with steel wool.
Dec 02, 2010 | Dayton Gas Furnace Heater
Where can I get a pilot orifice for a dayton 75000 btu lp heater
The Dayton Brand heater is sold by Grainger. You can get parts by going here
Sep 02, 2010 | Dayton (3E381) Gas Heater
Dayton torpedo heater 150 btu starts and runs about 15 seconds then shuts off. Lots of fuel
All these types of heaters use mostly the same parts and dealer for one brand carry parts for most brands. I have a tip at which explains the problem and where to get the parts to fix your unit. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
Mar 12, 2010 | Dayton Heating & Cooling
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
Where do i connect load wires to 240 volt baseboard heater
this is tricky to some you must connect heater to the load side of thermostat must will have a black set and a red set wires look at the directions to find the line side which you hook wires from panel to them I will tell you some switches are different so with out seeing the schmatics its hard to tell you email me a picof thomastat and i can tell you hope this helps
Oct 27, 2009 | Dayton Electric Heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Oct 27, 2009 | Dayton G73 Utility Heater
Do you have the installation instructions, they will tell you exactly where to attach your high voltage.
Oct 27, 2009 | Heating & Cooling
Dayton 511 Utility Heater Logo
409 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
