Question about Gateway Computers & Internet
I think i may have deleted mcaffee,now i can't load things and it takes too log. i only have 192mb on disk i was trying to make room,but screwed up!
  • 32 Answers
DELETE EVERYTHING FORM MCAFFE(including registry entries) and reinstall it.
Posted on Oct 30, 2008
Is there a way to make a bootable usb for win 7 without a win 7 disk, for an acer aspire 1 d257 which has no cd rom
Download a Windows 7 ISO to USB , 3.5GB's more or less, and open Boot Menu,Boot from USB. Of course you will have to but the Product Key : http://www.mydigitallife.info/official-windows-7-sp1-iso-from-digital-river/ When you deleted McAfee, did you use the McAfee Removal Tool from the McAfee website? Did you try a System restore/recovery? Unplug, remove battery, plug in, try another restore, you may have to repeat, unplug each time.
Feb 08, 2013 | Acer Aspire One PC Notebook
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
Couple of things my mac start up disk there is a message saying it is close to be full i deleted over 900 files and it is still giving me that message second is when i try to edit a track in garage band...
The only reason you would still be using disk space is if you haven't Emptied the trash can (assuming you deleted files that are large enough to count.) On the Dock you can Click on the Trash, in the right upper side of the window is an Empty button. Press that and you should end up with an empty window. If you get an error about deleting certain files, try holding down the Option key on the keyboard when you click Empty. If this doesn't help download "Disk Inventory X" (a free utility, google it) to see where your file space is going. Sometimes you delete a bunch of stuff, but a log for or something else has gone crazy and is still taking up all the space. Disk Inventory X will help you see that kind of thing. Hope that helps.
May 18, 2011 | Apple MacBook Mac Notebook
I have mainboard Amptron ZX-I945LM4,but i can't install any varsions of windows xp.i try change settings in bios,jumpers,but still same.tahnkl you for help
try to delete all of your partitions.
Then boot from cd the bootable setup disk of windows xp.
try a working setup disk.
1. if you still cant install windows xp,try to make a new partition and add all the contents of the setup disk into that partition. boot from cd and you will be able to go to setup screen.
Pm me if problem persists.
:) thank you
Aug 10, 2009 | Computers & Internet
It keeps saying opertion failed when i try to load a project, I changed harddrives and it does the same thing
Try checking the disk drive and CD drive connectors on the main circuit board, see if there are any bent, dirty or desoldered pins.
That's one thing you can do, and it may either help or not, but many machines that use disk/CD/floppy drives show an error message if there is a connection problem so i guess it's at least worth checking it.
regards
3rq8 (Triarcuate)
Aug 01, 2009 | Roland Mv-8000 Sampling/Record Production...
I can log in to my yahoo account, but when I go to the e-mail part, it loads a blank page, and the thing at the bottom says "done", like it thinks the page has loaded! I have tried other computers and it...
You should be able to see those emails after hitting F5 from the keyboard a couple of times. This is often caused by server connectivity problems.
Also, try clearing your cache:
For IE, click Tools, Internet Options. In the general tab, under Delete browsing history, delete ALL.
Further, flush your DNS. Open a command prompt, then type:
ipconfig /flushdns
Jul 15, 2009 | Yahoo Mail
My xp home sp3 wants a least 2 restarts before it
"Wants a reboot?" That's strange.
If you have the McAffee software available for re-installation - I would remove McAffee (UNPLUG YOUR NETWORK CABLE, as you'll be naked to the world) and see if it boots OK without McAffee.
If it is happy to boot without McAffee, then try re-installing McAffee and see how it acts.
You can always use something other than McAffee if it ends up being the culprit of your problems.
Also, check for malware. Download MalWare Bytes (http://www.malwarebytes.org) and make sure to update the definitions and run it across your computer. The Quick Mode is effective, and the Thorough Mode takes hours .... :)
Just make sure to be careful when you have no AntiVirus installed to not go playing on the internet .... download MalWare Bytes (install & update) before you remove McAffee and unplug from the world.
Jun 14, 2009 | Microsoft Windows XP Home Edition
My Laptop suddenly takes 15 minutes to turn on from the loading screening (where it says acer after its turned on and the blue loading bar is going) and simple tasks are now slower, such as the media...
The best thing you can do is add more RAM. As more programs and documents are loaded the more RAM it needs. However, there are also a couple of other things you can try first. This will clean up all the old /tmp files that are not needed and also fix your hard drive so all the data is together and not spread out.
click on start>programs>accessories>system tools>disk cleanup. Run this first to get rid of the junk files that are left on your computer by websites
After the disk cleanup go back to the same location and run Defrag.
Each time you delete a file it leaves a blank space on the hard drive. after a while it takes longer to find files. The defrag will push all the data together in a row so it is faster to find.
Hope this helps.
Don't forget to rate this solution before you log off.
Jan 26, 2009 | Computers & Internet
98fe pc full memory
welcome to fixya
your back up files you wish to delete ?
well easiest way would be do a disk clean an on the list check everything and it should clear out all log and windows stuff your not using ....if not you can goto other drive in my computer and remove the stuff there manualy witch your more then liklely going to have to do .....might want to eaither remove it or get another hd ... maybe a bigger hd
hope this helps you out have a great day :)
Aug 11, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
