Question about Canon MV600 Mini DV Digital Camcorder
Black Viewfinder & Screen.
This problem came on suddenly and only occours when recording. When switched to record mode, the viewfinder and the lcd screen is completely black as if the lenscap were still on. The screen information: Rec/Pause: W/S: Tape Remaining: etc. are all present but it only records complete darkness. Playback (of previously recorded material is perfect and I have tried all camera settings and new tapes to remedy the problem but to no avail. If anyone can help I would very grateful. Thank you.
  • 3 more comments
  • becn Feb 06, 2008
    happened suddenly, lens cap was off switched to record (camera) mode and nothing, black screen. I checked the cap, and tried recording. Sound recorded, but nothing. I was outside at the time, but when I went inside noticed that there were some visible images in negative (reverse mode).
  • zanteley May 26, 2008
    Cleaned with Head Cleaner screen clear for a about one second then black
    again no better.
  • philice May 31, 2008
    when you turn the mv600 on and get ready to record it is as if you still have the lens cover on. the screen is all black if you keep it on long enough it some times clear its self.
  • Anonymous Jul 02, 2008
    I have the same problem as described here. The problem came on suddenly, just after charging the battery which is now fully charged. I tried changing the tape and fiddling with menu settings but nothing helped. I can watch previously recorded material, but can only record darkness.
  • adsy16 Jul 05, 2008
    when i turn my canon vid camera on there is a black screen i cannot record ?why?
GUEST! Do you happen to have their number handy? I am in Australia but going to the UK for a wedding - and I will be in Manchester - apparently 1 day by express post away from Plymcare Devon - and obviously, have the same problem (I totally blamed my clumsy friend for killing the camers - it just died in his hands - now I owe him a BIg apology!) :)
I'll check in again!
GG
Posted on Mar 29, 2008
Thousands of us have had this problem with Canon MV600 camcorders, and now they have aknowledged there is a problem and are repairing them for free!! Get in touch with Plymcare, Marshall Road, Devon PL7 1YB (sorry didn't write their number down). Or just remove battery and tape and send it to them - you'll get it back within a week, working like new, totally free. Just got mine back and filmed my 5 1/2yr old for first time since it went off on her 3rd birthday!
Posted on Mar 19, 2008
  • 64 Answers
When you zoom in and out is the lens moving, if its not then quite possibly the flex has come loose or its the mainboard, thats the only two things that can cause your problem. i am a canon repair tech for video and it should be sent in for service sorry.
Posted on Nov 17, 2007
  • 188 Answers
Normally there are two reasons for the given problem. 1). Bad or defective CCD. and/or 2). shutter not working. in the first case the only solution is the replacement of the CCD. and in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Posted on Sep 14, 2006
SOURCE:
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
My canon gl2 lcd screen and viewfinder black
Same thing happened to me. No display, no menu, no S-video output while in camera mode, but in VCR mode all was OK. Turning power off and on did not help until I also disconnected the AC power adapter. BTW, Mr. Riggins did not read the question before he answered.
Nov 25, 2012 | Canon GL2 Mini DV Digital Camcorder
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Not seeing anything through the viewfinder when switched on
Most cameras and video recorders now display picture either through the viewfinder or the LCD screen.
Your camera model allows the same. Although if you turn the lcd screen towards the subject (screen faces the same direction as the lens) then the viewfinder switches on.
Sep 26, 2009 | Canon ZR200 Mini DV Digital Camcorder
No picture on lcd & view finder
PLease see http://www.fixya.com/support/t131881-sony_cam_recorder_wont_record for more information on this i have had the same problem, faulty CCD image processor chip.
Apr 01, 2008 | Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon MV600 Mini DV Digital Camcorder Logo
282 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
