Question about Epson Stylus Photo R1800 InkJet Printer
Ink got into pads, is my printer ruined?
Was trying to print on roll paper and it didn't feed, and the ink got into the spongy pads. I've used rubbing alcohol to clean, plus a towel to soak up, but what do i do next? there has to be a way to replace the spongey things, or will the ink just dry and I'll be OK? Guess I should wait to print anything for a couple of days? Thanks
  • lilithanna Nov 13, 2008
    it has seemed OK but definitely I will try this - thank you so much! I won't panic. And I voted. Thanks for posting.
    Scholar:
  • 121 Answers
You have cleaned well it should be ok if not i suggest you clean it well to avoid inks marking your print outs....and than when you have cleaned well...remove cartridge and using hair dryer if available dry the pads thoroughly..you should be OK..
no need to panic
please do vote!
Cheers!
Posted on Nov 13, 2008
Epson Printer Problem
HI,
Press the fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
Jul 24, 2008 | Epson Office Equipment & Supplies
Ink has run out ??? it no longer prints... TSP100 How do we change the ink roller/cartridge or whatever it requires?
TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
  • check the paper roller, it can be wrong installed.
  • Check the upper cover if not closed properly close it.
  • check the print head or the pressor roller.
Jun 13, 2011 | Star Micronics TSP100 Thermal Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Mar 13, 2011 | Epson Office Equipment & Supplies
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
Paper not going through feeder paper going off to one side of printer
Usually this is caused by a piece of torn paper occulding the paper path. or a shiny area on the paper feed rollers.
1) for paper jam: Use a peice of stiff card and place it in the printer use word pad to print a single full stop and that will start the card to begin to roll through the path. apply some push to it to keep it straight in the effort to snag that paper and have it ppushed out of the rollers
Yse a plastic polly mit and run over rollers to slightly roughen them and remove the ink shoine on them, especially the side that has the problem.
Feed a new piece of paper into the printer and check that it is now printing correctly
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Waste Ink Counter Reset Tools Download Resetting
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 12, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
May 30, 2008 | Sharp EL-1801P Calculator
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
HP PSC1510 Feeds paper half out then stops
Clean the roller that feeds the paper (located at the right side inside the feeding tray).
I did it ,with a cotton pad: first impregnated with water an soap, then only with water to clean the soap and then with a dry pad. I did making the roll to roll printing a page without paper in the try and continuosly presing the cancel/resume button.
Mar 11, 2008 | HP PSC 1510 All-In-One InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
