Question about Cannon Office Equipment & Supplies
Just put a black and color cartridge in the printer the printer says wait then it sayscheck ink 0053 black colori hit o.kand it still says check ink the printer is the mx300 and i have it less than a year pleaseanswer and advise nat salinger nats2306@comcast.net or call 5614459635 thank you
Did you pull the tape OFF the cartridge? It covers the copper traces on the back of the cartridge.
Hope this helps!
Posted on Oct 30, 2008
I replaced the color ink cartridge. Now there is an "E" flashing alternately with a "5". The alarm light is on steadily, and the black ink and color ink lights are flashing. How do I...
E5 is a Cartridge cannot be recognized error.
Reinstalling the cartridge could clear the alarm.
If this does not work,
Removed both ink cartridges.
Turn off printer and unplug fron electrical outlet.
Wait at least 5 minutes.
This will let the printer reset itself.
Plug printer back in and turn on.
Printer will cycle and an E5 will appear.
Installed back ink cartridges.
Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Under Attention, orange lights are flashing for black and white and color. I have put new ink cartridges in turned on and off and still flashing orange. Wher it says Start/Copy, a big E is flashing. ...
I would try to remove both ink cartridges.
Close cover and turn off printer and unplug from outlet.
Wait at least 15 minutes, this will let printer to completely reset.
Turn on printer and wait for printer to stop.
Install both ink cartridges.
Jan 09, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
How do I change the ink on the Epson Stylus TX300? Thanks.
Just follow the following steps:
#1
The printer should be turned on and not printing. Refer to control panel to see which cartridge is empty.
#2
Hit the printer "Menu" button until you get to "Change Cartridge." At this point, hit "Color Copy" to move the cartridges into proper replacement alignment.
#3
Open the top of the printer and pull open the tab for the ink cartridge you are replacing. The black cartridge can be found to the left, while the color cartridge is on the right.
#4
Pull the cartridge out.
#5
Get the new cartridge ready to install. Before putting it in, pull off the yellow tape on the bottom.
#6
Push the cartridge into the appropriate slot, and click the tab securely shut.
#7
Close the top of the printer until it clicks securely.
#8
Wait 30 seconds or so for the ink to initiate. The on button will flash during the process and then stop flashing and stay lit when it's done.
Thanks
Oct 03, 2010 | Office Equipment & Supplies
Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black Cartridge Not Being Used While Printing
try printing in monochrome mode or gray-scale mode, and specify that it use only the black cartridge.
another problem could be that the head have gotten dry, remove the cartridge, get a soft cotton towel, wet it with a little bit of water, put the head of the cartridge (where the ink comes out from) on the cotton towel, you will see some ink come out of the cartridge, if yes, then put the cartridge back into the printer, and give it a try.
if not try to blow some air into the cartridge as if doing CPR ;) to the cartridge, this will help the ink get out of the cartridge.
if all this fails, get a new cartridge, as sometimes the head could have gotten damaged.
good luck
Mar 25, 2009 | Dell A940 All-In-One InkJet Printer
Check Black Ink blinking...???
Remove the ink cartridges
Remove the printhead
Close the access door w/o anything in the printer
wait for a few minutes
Install the printhead only
install the color ink cartridge
install the black ink cartridge
if the error still there ( Repeat the cycle 5x)
or go to www.kodak.com/go/itg
Mar 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Pic`s wrong colors
you need to check
1) same color ink of the cartridge almost empty, change a new ink cartridge or refill the color ink (there is only one ink cartridge)
2) the cartridge ink channel dryer and constipated, take out the cartridge put the bottom surface touch down clean water (a little) 1 hr, then set back if the cartridge has enough ink.
Feb 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
26 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Victorman
Victorman
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
