LG tromm error code 0E - Washing Machines
  • boopers289 Mar 23, 2009
    I have this same problem & have cleaned out the filter & small drain hose & still have the same problem. So how do I get to the pump impeller to check or replace it?
  • murdlarry1 Apr 28, 2009
    where is the pump impeller
  • 1,543 Answers
That's not OE, that's DE as in Drain Error. Open the access panel on the lower left front of the machine, use the small hose to drain out the remaining water, then unscrew the large plug and clean out the filter attached to the plug. If there is nothing in the filter, you may have a blocked pump impeller (not very likely as the filter stops most objects) or the pump impeller may have come off the pump motor shaft. If the later, replace the pump motor, as just popping the impeller back on will only result in repeat of your problem.
Posted on Oct 31, 2008
SOURCE: LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
Posted on May 16, 2009
  • 497 Answers
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Posted on Sep 15, 2009
SOURCE: my LG Tromm washing machine
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Posted on Oct 10, 2008
SOURCE: on my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Posted on Dec 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: My LG Tromm washer WM2277hs
OE: Drain problem took longer than 10 minutes to drain
Posted on Sep 03, 2011
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
Model Wm2496HSM will not spin and drain
Jodie, the OE fault is a drain problem. First thing to look at is the pump coin trap on the bottom of the washer behind the little door. If the washer has water in it, pull out the little hose, remove the stopped at the end and drain into a shallow bucket. When the water stops, removed the trap by twisting the trap handle counter clock wise. If it is full of "stuff" clean it and reinstall it. If it is clean, then you either have a bad pump or something stopping the pump.
Apr 10, 2014 | LG Washing Machines
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
On my frontload LG tromm I have the error code EO it will
Nov 28, 2009 | LG WM1814CW Front Load Washer
I have an LG TROMM wm1812cw washer. Out of the blue the machine will not spin or drain. It has given an an error code OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm washing machine WM1812CW keeps coming up with error 0E. how can I fix it.
Jun 01, 2008 | Washing Machines
Washing Machines Logo
1,957 people viewed this question
Top Washing Machines Experts
