Question about Samsung Digimax D53 Digital Camera
Beeping My batteries went dead in my camera and I went out and brought some more, as soon as I try to turn it on it beeps really loud and then shut off. I then went and brought some Duracell batteries and it's still doing the same thing
  • 3 Answers
Did you try this?
Well I have had similar problems with this camera model. I tried several types of batteries and changed the battery type settings from the menue too... the problem changed a little bit but it did not solve the issue. I send the camera to Samsung service but got it back with "no fault found".
as I am working in this business I could not believe that a camera like this is not able to make less than 10 pictures with one set of batteries....I gave not up.
here is what I found:
when you open the camera by releasing the little screws from the buddy you will find several connector clips holding flatcables. this clips have not been closed correctly. just close them carefully!!! with a forceps and you will have a nice camera! this work can't be done in hurry...so take your time.
Posted on Nov 02, 2008
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
When i try to turn my camera on it beeps 3 times and shuts off.
It must be the end of the Samsungl camera battery life made this matter ,why not change the Samsung digital camera battery for a try.It is a simple but usual problem.
Jun 02, 2010 | Samsung S860 Digital Camera
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Samsung NV10 heeelp!Pleeease
Not sure about the battery... that could be it and I haven't tried switching it out for a new one yet, but in the meantime I am getting around this problem my grabbing the lens with my fingers and "helping" come all the way out... just give it a little pull, a little encouragement and it will come all the way out... but the trick is that you have to do it right after you try to turn it on and before you get the beeps...
So if your lens is stuck out right now and the camera is powered off, then turn the camera on and then pull the lens out before you get the beeps... once you give it a little tug, the mechanics should take over and it will extend all the way... the LCD will come on and you'll be good to go...
Like I said, I'm having this problem too and my girlfriend suggested we change the battery... I guess that's possible, that the battery is not holding enough of a charge to push the lens all the way out... I'll investigate how much a new battery costs and then determine if I think its worth a try...
Jul 10, 2008 | Samsung NV10 Digital Camera
Why is the camera beeping?
I had t he three beep problem and also the lens was open. I tried batteries - then i noticed the lens was slightly bent - i tried straightening and it snapped and went into place. then i tried turning it on and it was fine and when i turned it off the lens closed.
Maybe your lens is bent.
Jun 28, 2008 | Samsung Digimax S730 Digital Camera
My camera is broken
dear samanthaj
My camera did the sae thing until I got duracell recharables. IT WORKS PERFECT NOW,,, as far as the camera staying on. TRY I..they're gREAT
May 30, 2008 | Samsung Digimax S630 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Camera won't work
I had the exact same problem. Camera turned on but turned off soon after, with lens still outside. Not to mention that awful beeping noise. I noticed the lens was crooked as if it was stuck. I pulled it out and I heard it click into place, for a second I thought I had broken it. I then turned it on . waited & it remained on, I turned it off and the lens went in and it turned off! It was working again. Good Luck!
Mar 19, 2008 | Samsung Digimax D53 Digital Camera
Camera beeps 3 times the shuts off
OMG! so i read all these suggestions and nothing worked or i was just confused..tried the tapping thing but didnt work..so i finally just kept twisting the lens and pushing it in and out..it doesnt really move but i was angry and hoping this was doing something..i turn my camera back on a IT WORKIN AGAIN:) im so happy becuz i was so pissed that i had to buy another camera but i suggest trying this method if the table tapping dont work..OH and my lens didnt look crooked at all so if urs look straight and stilling doing stupid beep thing ,,,try this!
Aug 24, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax D53 Digital Camera Logo
53 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
