Question about Canon Office Equipment & Supplies
E000823-0000 from canon 795 - Canon Office Equipment & Supplies
Can you please tell me how to print Fax activity report each time? means whenever I send a fax I need confirmation receipt thats its gone through.Can't find anything in Manual.
ACTIVITY REPORT
The FAX is factoryset to automatically print an ACTIVITY REPORT after every 20
transactions. If you want to print an ACTIVITY REPORT before it is automatically
printed, follow this procedure:
Transactions in an ACTIVITY REPORT are listed chronologically.
1 Press Function.
2 Press Report.
3 Press OK.
• The FAX prints an ACTIVITY
REPORT.
• If you prefer the FAX not to print an ACTIVITY REPORT after every 20 transactions,
disable the ACTIVITY REPORT setting ( p. 145).
• Please note that only one transaction number (TX/RX NO.) is assigned when you send
a document to several fax numbers in one operation.
ACTIVITY REPORT
PRINTING REPORT
27/12 2002 15:00 FAX 123 4567 CANON 001
ACTIVITY REPORT
ST. TIME CONNECTION TEL CONNECTION ID RESULT
* 27/12 13:43 905 795 1111 Canon CANADA 5001 AUTO RX ECM 1 OK 00'33
* 27/12 13:45 905 795 1111 Canon CANADA 0001 POLLING RX ECM 0 OK 00'00
0 STOP
* 27/12 13:51 03 3758 2111 Canon TOKYO 0002 B'CAST ECM 3 OK 01'18
* 27/12 13:53 2 887 0166 Canon AUSTRALIA 0002 B'CAST ECM 3 OK 01'18
* 27/12 14:10 905 795 1111 Canon CANADA 5002 AUTO RX ECM 1 OK 00'18
* 27/12 14:16 2 887 0166 Canon AUSTRALIA 5003 AUTO RX ECM 4 OK 03'59
* 27/12 14:27 20 545 8545 Canon EUROPA 0003 DELAYED TX ECM 1 OK 01'20
27/12 14:30 20 545 8545 Canon EUROPA 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:31 03 3758 2111 Canon TOKYO 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:57 2 887 0166 Canon AUSTRALIA 0005 TRANSMIT ECM 3 OK 01'25
0 STOP
27/12 14:59 1 432 2060 CANON OPTICS 0006 TRANSMIT 0 OK 00'01
0 #018
go to this site to download manual (see page 11-3)
http://files.canon-europe.com/files/soft30110/manual/FAX_L220_L295_UG_ENG.pdf
Dec 16, 2010 | Canon L220 Plain Paper Laser Fax
I have a PC-795 the paper feed doesn't take the paper completely through the copier. I also have a finger screw that has come out and I can't find where it goes.
throw the finger screw away. packing for the mirrors. look at the exp lamp are the ends black. if so change the ex lamp. causes jam at regi. otherwise change the feed clutch
Nov 10, 2010 | Canon PC-795 Copier
Canon Copier PC795 shuts off while copying. is
no there are no power supply,its NO LONGER available.you have some new ones like imagerunner 1020.
Oct 23, 2009 | Canon PC-795 Copier
Jamming canon 795
Check the sensors(photointerrupter) & toggle hanging up
Nov 20, 2008 | Canon NP 6050 Copier
Code E602-0001
E602 error means that there is a Hard Disk Drive problem ( 2.5inches Toshiba HDD that you should order to Canon, only a few models of HDD works on this machine )
Regards, Mug.
Nov 17, 2008 | Canon PC-795 Copier
Refilling cartridge
YOU CAN TAKE SPLIT THIS CARTRIDGE BY DEPRESSIN SMALL PLASTIC TABS AND 4 PHILLIPS SCREWS AND THIS CARTRIDGE WILL COME APART. YOU SORTA GOT LOOK AT IT AND SUDY WHAT HOLD IT TOGETHER. ACTUALLY TIME WISE IT IS CHEAPER TO BY READY MADE REFILLED CARTRIDGES FOR $30 TO$ 50.00 AND THEY WORK
Mar 27, 2008 | Canon PC-795 Copier
PC-795 Shuts Off Mid Copy
clean big rubber paper feed roller above paper tray with a microfibercloth moistened with rubbing alcohol.
open copier look in lower section under the toner cartridge you will see a black foam roller wipe it off also and then try to use.
Jan 17, 2008 | Canon PC-795 Copier
Pc795
pc 795 copier wont pull paper through,error light comes on,machine stops.
Dec 16, 2007 | Canon PC-795 Copier
Canon PC-795
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply! Good Luck!!!
Jun 06, 2007 | Canon PC-795 Copier
110 people viewed this question
old marine
old marine
