Question about Sharp FO 4450 Laser Fax
How to reset drum counter
Hi there how do you reset the drum counter on the sharp FO4450 fax
  • 328 Answers
Lift up the rapid key flap on the keyboard. press the life key and I think the display will give a choice of press 3 key and enter.
Posted on Oct 31, 2008
Drum life warning on toshiba dp120f
reset drum Counter for DP120
Turn fax off. Hold down 0, 1, 3 on numeric key pad and turn fax on. Then release the 0, 1 & 3 and enter the number 80, wait a few seconds and should see a message confirming counter has been cleared. Then turn fax off and on again
Jun 21, 2012 | Toshiba e-Studio DP170F Plain Paper Laser...
English manual for sharp fax machine model f0-455
You can download from this link :
http://office.manualsonline.com/manuals/mfg/sharp/fo4450.html
Hope this help and if helpful RATE please.
Feb 16, 2011 | Cameras
Sharp FO-4470: Error message is: "check cover or drum"
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Apr 23, 2010 | Sharp AR-F152 Fax
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Nov 03, 2009 | Sharp Office Equipment & Supplies
I am getting a message "maintenacne required code:dk"
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed.
here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html
Hope that helps.
Apr 10, 2009 | Sharp AR-BC260 Color Copier
LIGHT IS STILL ON WHEN i CHANGED THE DRUM ON THE
clear the drum counter. life than down arow until it says drum counter clear than start 2 times
Mar 23, 2009 | Sharp FO-DC535 Fax
How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Sep 19, 2007 | Office Equipment & Supplies
Sharp FO 4450 Laser Fax Logo
383 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
