Question about Panasonic PT-40LC12 40 in. LCD Television
Hard time turning tv on and once on, will turn off after a period of time
It usually takes 3 trys or more to turn the tv on. Each try the green light will flash for a while and then the red light blinks and the red lamp light will blink about every 4th time. Then when the tv turns on it will turn off again anywhere from immediately to a few hours of use at which time the red light blinks again along with the red lamp light. I seem to have an easiere time turning it on when it is warmer in the room. When I get home I turn the air on, so it's warm when I first get home. I tried switching out lamps. I had the lamp I took out when the "change lamp" light came on a year ago but get the same result. The tv worked fine before I moved but had it shipped in our last move and wonder if something go jarred loose.
  • 3,130 Answers
Sounds like it may have been jarred or theres a larger tall capacitor in the power supply that goes bad in these sets alot. Its not something a layman should attemt. As a matter of fact the only thing in this set that is user replaceable, is the lamp. Sorry but your going to need the service manual and soecialized tools tom trouble shoot this set. you really should seek out a pro for this repair.
Posted on Sep 12, 2006
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Tv turns off green light flashes twice and no
It trys to start but no picture? That means it's time to replace the lamp.
Apr 30, 2010 | Toshiba 62HM95 62" HDTV
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
Hard to get on 42in light flashes to come on but
I can help you if you tell me brand and model number of this set--I already have a good idea as to what may be wrong--it started slow--you had to turn it on several times at first to get on and once on it was ok?
I am online here now if you respond.
Remember, I do this for free.
Dec 19, 2009 | Televison & Video
Power problems
You have bad capacitors in the power supply.
Sep 03, 2009 | RCA D52W135D 52 in. TV/DVD Combo
Ps3 says cannot start the correct hard disk was not found
try safemode
hold down the power button while the console is in standby. the light will go from red to will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Black screen and no blinking green light when turned off
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-6 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i amafrikaans BUT PLZZZ RATE ME . . . plzz thns
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Vizio L37 Television
Truck not staring right
starter may be weak. usually they crank slow w/hot. i would start there.
Nov 08, 2008 | 2005 Nissan Frontier
Failure to start, period.
the whining you hear is most likely the color wheel
it need to reach a curtain rpm before the lamp will kick on
i will almost gurentee one of the colors is broken on the wheel
Mar 12, 2008 | Samsung HL-R5078W 50" HDTV
Panasonic PT-40LC12 40 in. LCD Television Logo
247 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
