Question about Whirlpool Dryers
BELT BROKE THE BELT BROKE ,WANTED TO KNOW HOW TO GET THE PART AND FIX IT
    Sergeant:
    Champion:
  • 324 Answers
Sears,com,
Posted on Oct 31, 2008
TIMER BELT BREAKING
I am assuming you mean timing belt as these cars did not come stock with timer belts. You need to get a timing belt and fix it. Just hope that when the belt broke you did not bend any valves as that will be costly to fix.
Jun 17, 2014 | 2001 Mitsubishi Galant
I have a Suzuki vitara 1990 soft top timing belt broke just wanted to know if it would have damaged anything else when it broke?
Yes . The valve stem will be bent so you will need a head job to fix them. To do the job properly replace the cam and crank shaft oil seals , tensioner pulleys and or hydraulic belt tensioner. Do not use 2nd hand belts. Remove all traces of oil from the area as oil is the biggest killer of timing belts
Nov 21, 2013 | Cars & Trucks
Serpentine belt broke on my 2003 mazda tribute
just loss of power to accessory's unless the timing belt jumped a tooth or more.
Jul 08, 2012 | 2003 Mazda Tribute
I wanted to know how to fix the start button light and also how to fix external USB ports
The only way is to replace LED and for USB port alway a broke contact of wiring. Good luck.
Sep 13, 2011 | Mercury Computers & Internet
The large belt that goes over several pulleys is not broken, the huge round thing attached to a rod broke off, there are no screws , it would have to be welded or replaced. I need to see a picture to show...
Hello srmlj: My name is Roger and I will help you. From what you described I would think either the water pump shaft broke or the belt tensioner broke. Attached is a belt diagram that lists the components that te belt runs. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Rogeraca6a01.jpg
Jan 15, 2010 | 1992 Buick Century
Timing belt broke -2000 ford focus zx3
Hello mawbea: My name is Roger I will answer your question. You did not say which engine is in your car. So if you have a 2.0 SOHC engine. If the belt broke you should be Ok. If you have the 2.0 DOHC engine. The likely hood of bending the valves are just about a guarantee. How ever with any engine using a timing belt it is possible to bend a valve.Should you need more help please just ask.
Please rate the quality of your answer as this way we know you received helpful information.Thank You for using Fix Ya, Roger
Jul 08, 2009 | 2000 Ford Focus
Serpentine belt broken
try these websites drivebelt diagram www.webcrawler.com and you can try www.autozone.com and www.alldatadiy.com for the most part you take a breaker bar and sometimes a socket and lift or push down on the tensioner also check the tensioner to make sure the spring did not break if it is then that is why your belt broke in the first place.
May 31, 2009 | 1992 Ford Explorer
Can you manually fix a VW jetta fan belt?
You can fix the fan belt yourself. It is best to buy the manual as it gives you insight/tips tricks to follow when changing this belt. It is usually very easy to do. Hope this helps you out! Thank you for Using FixYa!
Sincerely,
JC
Nov 20, 2008 | 2000 Volkswagen Jetta TDI
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
