Question about Honeywell Heating & Cooling
Installing thermastat took off amana thermastat and put on honeywell model rth3100c non programable, digital thermastat. but i did not lable wire when i disconnected wires. i put new honeywell on but can only get emergency heat. when i switch to air or heat i keep popping the 3 amp fuse in the relay circit which i just put on new cause i thought that was the problem till i found out my thermastat was bad.i was told by honeywell that it seems like i crossed a wire somewhere. but i need to know what color wire goes in what letter slot on honeywell since my old amana had some different letters on it and i also have a heat pump. .
  • 124 Answers
Any wire can go to any terminal. unfortunately you now have to hand trace each onre to the device it powers and hook it up accordingly. a daunting task even for a pro. having said that the installer could have used the normal colrs for the usual wiring if you were real lucky. as a general rule the red goes to the r terminal. the yellow goes to the y terminal. the white on a heat pump usually goes to w2. the green powers the fan and goes to g. usually the changeover valve is powered by the o terminal and that is usually wired with an orange wire. that only leaves two more wires. one is the auxilliary or emergency heat terminal and any color wire can be used for that. it will go back to the airhandler and tie on to the w terminal along with the white wire from the stat on most units. or they may have jumped the w and emergency terminal together and hooked the white wire to both. it will work either way. that only leaves one wire and that is the common wire to the stat taht allows it to light up and think and have power. . most stats need the red and a common to work. you may have bought a stat that works off battery power only but since you are blowing fuses it seems you have a common pulled on one wire that you have hooked up wrong and it is creating a dead short , aka a blown fuse. if you go to airhandler and finf low voltage terminal board look for terminal labeled comm . observe what color wire is connected to it and if that is the wire that goes off to the stat. if it is hooked to common and goes with the others to the stat then thats your common and should be hooked to your stat common terminal as outlined in your install sheet. you can keep replacing those fuses till you get it right or take a chance and use an amp probe and a jumper wire . only run an instant and if amps are 4, 5, 6, amps at trans your wrong. only test an instant or you will ruin transformer.probably best if you get a box of fuses.label stuff make notes and good luck. i have gotten in the habit of using a sharpie pen to make copius notes right on the service panel for me and the next guy.
Posted on Oct 30, 2008
I have a rth3100 that i installed programed it ac came on the next day went off and wont come on it was cycling on and of. After new one was installed dont have power to it
Here you can find all about Honeywell RTH3100C like wiring diagram and other informations. For example: thermostat wiring diagram, installation manual, installation, thermostat, wiring, manual.
Honeywell RTH3100C manual (user guide) is ready to download for free.
Apr 27, 2015 | Computers & Internet
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
Feb 06, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Changing From Trane to Honeywell
Color ---> New stat terminal
White------E and Aux.
Tan---------unused, tape and secure it
If there is Rh and Rc or R and Rh, these terminals should be jumpered together.
I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
Jun 13, 2013 | Honeywell RTH3100C - Digital Heat Pump...
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
How to wire rth3100c to tempstar heatpump
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 26, 2010 | Heating & Cooling
Wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Jul 24, 2009 | Heating & Cooling
I had an old thermostat that i had to change need wiring diagram
Go to
Dec 20, 2008 | Honeywell Electronic Programmable...
both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
Dec 20, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
108 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
